[mapguide-users] New UpdateFeatures problem
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Wed Apr 8 05:39:46 EDT 2009
Hello Klauss,
I have same problem and I'm really struggling with it. Have you solved
it?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Klaus
Lehtonen
Sent: Thursday, May 15, 2008 10:53 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] New UpdateFeatures problem
There have been similar problems with MG 2.0 using .NET in this list
before,
but the things mentioned in those posts did not solve my problem. I am
trying to add many features to a database using many UpdateFeatures
calls.
Usually if i try to add one or two features everything works fine. When
adding ten or more features only about 10% - 90% of the features go to
the
database and the rest give MgResourceBusyExceptions saying to try later.
I
also tried to add a delay when getting the exception and try again
later,
but that does not seem to work. This is pretty odd behavior as the
result
seems to be quite random.
View this message in context:
http://www.nabble.com/New-UpdateFeatures-problem-tp17248351p17248351.htm
l
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
