[mapguide-users] [MapGuide OSE FDO Oracle SL-King 0.8.5] Hole Polygon Type 7 Problem
rgourrat rgourrat at ag-carto.fr
Wed Apr 8 05:44:58 EDT 2009
in my Oracle DataBase, i have polygone without hole and with holes.
if i pass this query :
"select distinct a.geometry.get_gtype() from mytable a;"
return 7
Oracle Spatial User's Guide 10g.pdf says about this type :
"dl07 MULTIPOLYGON Geometry can have multiple, disjoint polygons (more
than one exterior boundary). (MULTIPOLYGON is a
superset of POLYGON.)"
Under MapGuide 6.5 polygons are displayed without problems !
but under MapGuide Ose 2.0.2, MapGuide Service Failed and it's neccessary to restart it.
After analyzed, i remark that :
if the polygon with hole have only one exterior boundary and the geometry type is 7, it's bad for MapGuide OSE.
if i put manually the geometry type at 3 with SQL+, it's diplayed under MapGuide OSE without problem.
do you think it's a FDO problem version ?
thanks for your help
View this message in context: http://n2.nabble.com/-MapGuide-OSE-FDO-Oracle-SL-King-0.8.5--Hole-Polygon-Type-7-Problem-tp2604217p2604217.html
