[mapguide-users] [MapGuide OSE FDO Oracle SL-King 0.8.5]
HolePolygon Type 7 Problem
Haris Kurtagic
haris at sl-king.com
Wed Apr 8 06:40:45 EDT 2009
Could be that it is King.Oracle provider.
As far as I can remember in some of previous releases there were
problems with some geometry types (which I thought are solved).
You could post just that geometry and I would check it ?
Also, with Fdo2Fdo you could check if King.Oracle can read that geometry
(you would need to copy latest provider to Fdo2Fdo).
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of rgourrat
Sent: Wednesday, April 08, 2009 11:45 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] [MapGuide OSE FDO Oracle SL-King 0.8.5]
in my Oracle DataBase, i have polygone without hole and with holes.
if i pass this query :
"select distinct a.geometry.get_gtype() from mytable a;"
return 7
Oracle Spatial User's Guide 10g.pdf says about this type :
"dl07 MULTIPOLYGON Geometry can have multiple, disjoint polygons (more
than one exterior boundary). (MULTIPOLYGON is a
superset of POLYGON.)"
Under MapGuide 6.5 polygons are displayed without problems !
but under MapGuide Ose 2.0.2, MapGuide Service Failed and it's
neccessary to restart it.
After analyzed, i remark that :
if the polygon with hole have only one exterior boundary and the
geometry type is 7, it's bad for MapGuide OSE.
if i put manually the geometry type at 3 with SQL+, it's diplayed under
MapGuide OSE without problem.
do you think it's a FDO problem version ?
thanks for your help
View this message in context:
http://n2.nabble.com/-MapGuide-OSE-FDO-Oracle-SL-King-0.8.5--Hole-Polygo
n-Type-7-Problem-tp2604217p2604217.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
