[mapguide-users] Maestro MgCooker Tiles
Berdel, Brian brian.berdel at mcmtrans.com
Wed Apr 8 15:37:11 EDT 2009
Thanks Kenneth, I was able to get working on another machine, so it is working on one of my layers now, but not my raster layer (sid files), still the same result.  They sid's do display properly otherwise.   Is there a proper way to add them in maestro so the cooker will work properly on them?  Currently just creating a composite by selecting the appropriate folder.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Wednesday, April 08, 2009 1:47 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Maestro MgCooker Tiles
The algorithm used in MgCooker is a little alternative, and I think its broken for some maps.
I have an improved version ready, but I need some legal stuff cleared before I can commit the fixes.
You can try building MgCooker from SVN, as there are some fixes in there already, but
the area it renders is likely way too big.
It sounds very strange that the cache is cleared when you view the map though.
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
I have recently tried testing Maestro's MGCooker (which will be great) with rasters as well as the Sheyboygan Base Layers.  When I check the TileCache I have nothing but 1kb png files that appear to be empty frames.    I let it run with my own rasters overnight...It finished with no errors, but when I went to view the base map, the entire TileCache was deleted and it started over creating new tiles that were correct.   Any idea what could be happening, or what I can look into for error's, etc? Logs show nothing...
Thanks,
Brian
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090408/b3e0b009/attachment.html
