[mapguide-users] [MapGuide OSE FDO Oracle SL-King 0.8.5]HolePolygon Type 7 Problem
djonio DJonio at miami-airport.com
Thu Apr 9 06:37:30 EDT 2009
ALL four(4) of your geometry examples are in fact VALID against our Oracle 10.2.0.3. (This 07 vs. 03 sdo_gtype would be a interesting question for Oracle: Like - Why is there a 03 type at all? Since when does MULTIPLE = one(1)? Good'ol Oracle math.)
Anyway, for any single geometry there is nothing in the spec that says anything about the order of the rings within SDO_ELEM_INFO_ARRAY. All the information that is needed to process each ring is there within SDO_ELEM_INFO_ARRAY so this makes sense to me.
I would hope Haris K. is listening in and has the time to delve into this.
Excellent and very well documented case I must add.
r,
dennis
View this message in context: http://n2.nabble.com/-MapGuide-OSE-FDO-Oracle-SL-King-0.8.5--Hole-Polygon-Type-7-Problem-tp2604217p2610378.html
