[mapguide-users] re ; mapguide integration with google maps
Berdel, Brian brian.berdel at mcmtrans.com
Thu Apr 9 09:46:20 EDT 2009
The KML does not work with the current version of google maps, this is a known issue for google.
If you are using fusion, you can theoretically overlay a mapguide map onto google maps in Fusion 2.0.
I started testing this last week, but have been too bogged down to finish testing.  I was able to overlay my map onto google maps, but there was a coordinate system issue and a problem setting the extents.
Jason wrote a script to fix an extent issue and also helped out with the coordinated system since Mapguide does not have it as an option.
So the short answer is that there is not an easy way to do it.   As soon as I get some time to finish testing with google maps and fusion2 I will document the procedure and post.   (But I am leaving for a long weekend this afternoon, so it will not be until next week...)
Brian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of girish kumar bv
Sent: Thursday, April 09, 2009 9:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] re ; mapguide integration with google maps
 Hi all,
I have created a marker layer(polygon layer)  from an xml  and overlayed the layer on my map in mapguide ,
now i need  to overlay the marker layer on google maps is this operation possible.
Or is it possible to convert marker layer into  tiles  and overlay on google maps.
Is there any in map open layers implementation to do the above mentioned functionality in mapguide ?
Can include google maps into mapguide frame on load and then add my map on it ?
Any help is appreciated.
[http://sigads.rediff.com/RealMedia/ads/adstream_nx.ads/www.rediffmail.com/signatureline.htm@Middle]<http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090409/9512d469/attachment.html
