[mapguide-users] Can't create layer using MySQL feature source
Stefan Dalakov
s.dalakov at mapware.net
Fri Apr 10 17:29:00 EDT 2009
Manel,
I have used MapGuide Studio 2008 to create this feature source.
Perhaps Kenneth can answer if this is a bug, or there is something extra
to be done in setting the feature source.
I have the same version of Maestro as yours.
Stefan Dalakov
Manel Gimeno wrote:
> Thanks Stefan.
> I copy and paste directly your XML (changing name, password,...) in
> Mapguide Maestro XML editor and it works fine.
> But as you said the server name appears under "Database" while
> "server" and "port" fields remain empty in Mapguide Maestro.
> Using directly Mapguide Maestro the XML generated is:
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> <Provider>OSGeo.MySQL</Provider>
> <Parameter>
> <Name>Username</Name>
> <Value>root</Value>
> </Parameter>
> <Parameter>
> <Name>Password</Name>
> <Value>password</Value>
> </Parameter>
> <Parameter>
> <Name>Service</Name>
> <Value>database at localhost:3306</Value>
> </Parameter>
> <Parameter>
> <Name>DataStore</Name>
> <Value />
> </Parameter>
> </FeatureSource>
> It is quite different as your and it doesn't work. Maybe there is a
> bug in Maestro or I need to upgrade my version, I'm using Mapguide
> Maestro version 1.0.9.15919
> Regards
> Manel Gimeno
> ----- Original Message -----
> *From:* Stefan Dalakov <mailto:s.dalakov at mapware.net>
> *To:* MapGuide Users Mail List
> <mailto:mapguide-users at lists.osgeo.org>
> *Sent:* Monday, April 06, 2009 8:03 PM
> *Subject:* Re: [mapguide-users] Can't create layer using MySQL
> feature source
> Here is the FeatureSource
> I find interesting thing here.
> When I open this FeatureSource in MG Studio I see
> my server name appearing under "Service"
> In Maestro the same server name appears under "Database", while
> "server"
> and "port" fields remain empty.
> Do you have MG Studio ?
> How did your data get in MySQL format ?
> If you don't manage, mail me directly, not thru the list and I
> will send
> you the pwd.
> Stefan Dalakov
> <Parameter>
> <Value>%MG_USERNAME%</Value>
> </Parameter>
> <Parameter>
> <Value>%MG_PASSWORD%</Value>
> </Parameter>
> <Parameter>
> <Value>mysql2.winhostingcenter.com</Value>
> </Parameter>
> <Parameter>
> <Value>technop_mg</Value>
> </Parameter>
> <SupplementalSpatialContextInfo>
> <Name>Default</Name>
> <CoordinateSystem>LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local
> Datum",0],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
> </SupplementalSpatialContextInfo>
> <ConfigurationDocument>config.xml</ConfigurationDocument>
> </FeatureSource>
> Manel Gimeno wrote:
> > Thanks Stefan.
> > I think the main problem is in the connection to MySQL. Even
> Mapguide
> > Maestro says that there is no error reported I've tried to use the
> > FeatureSource to connect using MapAgent/Test connection and the
> test
> > doesn't work (it return false).
> > Could you send me your FeatureSource XML to try to find where the
> > problem is?
> > Thanks in advance
> > Manel Gimeno
> > *Sent:* Monday, April 06, 2009 4:48 PM
> > feature source
> > Hi Manel,
> > Here is a layerDefinition that works for me.
> > Have you specified Coordinate-System-Overrides ?
> > Stefan Dalakov
> > <?xml version="1.0" encoding="UTF-8" ?>
> > - <#> <LayerDefinition
> > xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
> > xsi:noNamespaceSchemaLocation="*LayerDefinition-1.1.0.xsd*"
> > version="*1.1.0*">
> > - <#> <VectorLayerDefinition>
> > <ResourceId>Library://mysql_ds.FeatureSource</ResourceId>
> > <FeatureName>Fdotechnop_mg:links</FeatureName>
> > <FeatureNameType>FeatureClass</FeatureNameType>
> > - <#> <PropertyMapping>
> > <Name>LAYER</Name>
> > <Value>LAYER</Value>
> > </PropertyMapping>
> > <Name>LENGTH</Name>
> > <Value>LENGTH</Value>
> > </PropertyMapping>
> > <Geometry>ogc_geom</Geometry>
> > - <#> <VectorScaleRange>
> > - <#> <PointTypeStyle>
> > <DisplayAsText>false</DisplayAsText>
> > <AllowOverpost>false</AllowOverpost>
> > - <#> <PointRule>
> > <LegendLabel />
> > </PointRule>
> > </PointTypeStyle>
> > - <#> <LineTypeStyle>
> > - <#> <LineRule>
> > <LegendLabel>'Main Pipe'</LegendLabel>
> > <Filter>"LAYER" = 'Main Pipe'</Filter>
> > - <#> <LineSymbolization2D>
> > <LineStyle>Solid</LineStyle>
> > <Thickness>2</Thickness>
> > <Color>FF000000</Color>
> > <Unit>Points</Unit>
> > <SizeContext>DeviceUnits</SizeContext>
> > </LineSymbolization2D>
> > </LineRule>
> > - <#> <LineRule>
> > <LegendLabel>'Pipeline'</LegendLabel>
> > <Filter>"LAYER" = 'Pipeline'</Filter>
> > <Color>FF000080</Color>
> > <Unit>Points</Unit>
> > </LineRule>
> > - <#> <LineRule>
> > <LegendLabel />
> > <Thickness>0.0</Thickness>
> > <Color>ff000000</Color>
> > <Unit>Centimeters</Unit>
> > </LineRule>
> > </LineTypeStyle>
> > - <#> <AreaTypeStyle>
> > - <#> <AreaRule>
> > <LegendLabel />
> > - <#> <AreaSymbolization2D>
> > - <#> <Fill>
> > <FillPattern>Solid</FillPattern>
> > <ForegroundColor>ffffffff</ForegroundColor>
> > <BackgroundColor>ff000000</BackgroundColor>
> > </Fill>
> > - <#> <Stroke>
> > </Stroke>
> > </AreaSymbolization2D>
> > </AreaRule>
> > </AreaTypeStyle>
> > </VectorScaleRange>
> > </VectorLayerDefinition>
> > </LayerDefinition>
> > Manel Gimeno wrote:
> >> Hi all,
> >> I've created a MySQL FeatureSource in Mapguide 2.0 using
> Mapguide
> >> Maestro 1.0.9.15910. When I click in the test connection button
> >> no error is reported, so it seems the connection to MySQL
> works fine.
> >> When I try to create a FeatureLayer using the MySQL
> FeatureSource
> >> previously defined the following error happens after selecting
> >> the FeatureSource as resource:
> >> "Failed to read schema from data source.
> >> The operation gave the error message: Error en el servidor
> >> remoto: (559) MgConnectionFailedException.:
> >> Cannot establish connection.
> >> Exception occurred in method
> >> MgServerDescribeSchema::ExecuteDescribeSchema() at line 173 in
> >> file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
> >> Can anyone help me to solve this problem? (Maybe if you have an
> >> example of XML LayerDefinition using a MySQL FeatureSource...)
> >> Thanks in advance
> >> Manel Gimeno
> >> _______________________________________________
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090411/256cf4ac/attachment.html
