[mapguide-users] Can't create layer using MySQL feature source
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Apr 14 02:45:41 EDT 2009
Yes, that is a bug Maestro.
I will fix it, thanks for finding it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Stefan Dalakov skrev:
> Manel,
> I have used MapGuide Studio 2008 to create this feature source.
> Perhaps Kenneth can answer if this is a bug, or there is something
> extra to be done in setting the feature source.
> I have the same version of Maestro as yours.
> Stefan Dalakov
> Manel Gimeno wrote:
>> Thanks Stefan.
>> I copy and paste directly your XML (changing name, password,...) in
>> Mapguide Maestro XML editor and it works fine.
>> But as you said the server name appears under "Database" while
>> "server" and "port" fields remain empty in Mapguide Maestro.
>> Using directly Mapguide Maestro the XML generated is:
>> <?xml version="1.0" encoding="utf-8"?>
>> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>   <Provider>OSGeo.MySQL</Provider>
>>   <Parameter>
>>     <Name>Username</Name>
>>     <Value>root</Value>
>>   </Parameter>
>>   <Parameter>
>>     <Name>Password</Name>
>>     <Value>password</Value>
>>   </Parameter>
>>   <Parameter>
>>     <Name>Service</Name>
>>     <Value>database at localhost:3306</Value>
>>   </Parameter>
>>   <Parameter>
>>     <Name>DataStore</Name>
>>     <Value />
>>   </Parameter>
>> </FeatureSource>
>> It is quite different as your and it doesn't work. Maybe there is a
>> bug in Maestro or I need to upgrade my version, I'm using Mapguide
>> Maestro version 1.0.9.15919
>> Regards
>> Manel Gimeno
>>     ----- Original Message -----
>>     *From:* Stefan Dalakov <mailto:s.dalakov at mapware.net>
>>     *To:* MapGuide Users Mail List
>>     <mailto:mapguide-users at lists.osgeo.org>
>>     *Sent:* Monday, April 06, 2009 8:03 PM
>>     *Subject:* Re: [mapguide-users] Can't create layer using MySQL
>>     feature source
>>     Here is the FeatureSource
>>     I find interesting thing here.
>>     When I open this FeatureSource in MG Studio I see
>>     my server name appearing under "Service"
>>     In Maestro the same server name appears under "Database", while
>>     "server"
>>     and "port" fields remain empty.
>>     Do you have MG Studio ?
>>     How did your data get in MySQL format ?
>>     If you don't manage, mail me directly, not thru the list and I
>>     will send
>>     you the pwd.
>>     Stefan Dalakov
>>       <Parameter>
>>         <Value>%MG_USERNAME%</Value>
>>       </Parameter>
>>       <Parameter>
>>         <Value>%MG_PASSWORD%</Value>
>>       </Parameter>
>>       <Parameter>
>>         <Value>mysql2.winhostingcenter.com</Value>
>>       </Parameter>
>>       <Parameter>
>>         <Value>technop_mg</Value>
>>       </Parameter>
>>       <SupplementalSpatialContextInfo>
>>         <Name>Default</Name>
>>         <CoordinateSystem>LOCAL_CS["Non-Earth
>>     (Meter)",LOCAL_DATUM["Local
>>     Datum",0],UNIT["Meter",
>>     1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
>>       </SupplementalSpatialContextInfo>
>>       <ConfigurationDocument>config.xml</ConfigurationDocument>
>>     </FeatureSource>
>>     Manel Gimeno wrote:
>>     > Thanks Stefan.
>>     > I think the main problem is in the connection to MySQL. Even
>>     Mapguide
>>     > Maestro says that there is no error reported I've tried to use the
>>     > FeatureSource  to connect using MapAgent/Test connection and
>>     the test
>>     > doesn't work (it return false).
>>     > Could you send me your FeatureSource XML to try to find where the
>>     > problem is?
>>     > Thanks in advance
>>     > Manel Gimeno
>>     >     *Sent:* Monday, April 06, 2009 4:48 PM
>>     >     feature source
>>     >     Hi Manel,
>>     >     Here is a layerDefinition that works for me.
>>     >     Have you specified Coordinate-System-Overrides ?
>>     >     Stefan Dalakov
>>     >     <?xml version="1.0" encoding="UTF-8" ?>
>>     >     - <#> <LayerDefinition
>>     >     xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
>>     >     xsi:noNamespaceSchemaLocation="*LayerDefinition-1.1.0.xsd*"
>>     >     version="*1.1.0*">
>>     >     - <#> <VectorLayerDefinition>
>>     >       <ResourceId>Library://mysql_ds.FeatureSource</ResourceId>
>>     >       <FeatureName>Fdotechnop_mg:links</FeatureName>
>>     >       <FeatureNameType>FeatureClass</FeatureNameType>
>>     >     - <#> <PropertyMapping>
>>     >       <Name>LAYER</Name>
>>     >       <Value>LAYER</Value>
>>     >       </PropertyMapping>
>>     >       <Name>LENGTH</Name>
>>     >       <Value>LENGTH</Value>
>>     >       </PropertyMapping>
>>     >       <Geometry>ogc_geom</Geometry>
>>     >     - <#> <VectorScaleRange>
>>     >     - <#> <PointTypeStyle>
>>     >       <DisplayAsText>false</DisplayAsText>
>>     >       <AllowOverpost>false</AllowOverpost>
>>     >     - <#> <PointRule>
>>     >       <LegendLabel />
>>     >       </PointRule>
>>     >       </PointTypeStyle>
>>     >     - <#> <LineTypeStyle>
>>     >     - <#> <LineRule>
>>     >       <LegendLabel>'Main Pipe'</LegendLabel>
>>     >       <Filter>"LAYER" = 'Main Pipe'</Filter>
>>     >     - <#> <LineSymbolization2D>
>>     >       <LineStyle>Solid</LineStyle>
>>     >       <Thickness>2</Thickness>
>>     >       <Color>FF000000</Color>
>>     >       <Unit>Points</Unit>
>>     >       <SizeContext>DeviceUnits</SizeContext>
>>     >       </LineSymbolization2D>
>>     >       </LineRule>
>>     >     - <#> <LineRule>
>>     >       <LegendLabel>'Pipeline'</LegendLabel>
>>     >       <Filter>"LAYER" = 'Pipeline'</Filter>
>>     >       <Color>FF000080</Color>
>>     >       <Unit>Points</Unit>
>>     >       </LineRule>
>>     >     - <#> <LineRule>
>>     >       <LegendLabel />
>>     >       <Thickness>0.0</Thickness>
>>     >       <Color>ff000000</Color>
>>     >       <Unit>Centimeters</Unit>
>>     >       </LineRule>
>>     >       </LineTypeStyle>
>>     >     - <#> <AreaTypeStyle>
>>     >     - <#> <AreaRule>
>>     >       <LegendLabel />
>>     >     - <#> <AreaSymbolization2D>
>>     >     - <#> <Fill>
>>     >       <FillPattern>Solid</FillPattern>
>>     >       <ForegroundColor>ffffffff</ForegroundColor>
>>     >       <BackgroundColor>ff000000</BackgroundColor>
>>     >       </Fill>
>>     >     - <#> <Stroke>
>>     >       </Stroke>
>>     >       </AreaSymbolization2D>
>>     >       </AreaRule>
>>     >       </AreaTypeStyle>
>>     >       </VectorScaleRange>
>>     >       </VectorLayerDefinition>
>>     >       </LayerDefinition>
>>     >     Manel Gimeno wrote:
>>     >>     Hi all,
>>     >>     I've created a MySQL FeatureSource in Mapguide 2.0 using
>>     Mapguide
>>     >>     Maestro 1.0.9.15910. When I click in the test connection
>>     button
>>     >>     no error is reported, so it seems the connection to MySQL
>>     works fine.
>>     >>     When I try to create a FeatureLayer using the MySQL
>>     FeatureSource
>>     >>     previously defined the following error happens after selecting
>>     >>     the FeatureSource as resource:
>>     >>     "Failed to read schema from data source.
>>     >>     The operation gave the error message: Error en el servidor
>>     >>     remoto: (559) MgConnectionFailedException.:
>>     >>     Cannot establish connection.
>>     >>     Exception occurred in method
>>     >>     MgServerDescribeSchema::ExecuteDescribeSchema() at line 173 in
>>     >>     file
>>     d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
>>     >>     Can anyone help me to solve this problem? (Maybe if you
>>     have an
>>     >>     example of XML LayerDefinition using a MySQL FeatureSource...)
>>     >>     Thanks in advance
>>     >>     Manel Gimeno
>>     >>     _______________________________________________
>>     >>     mapguide-users mailing list
>>     >>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090414/8acfb676/attachment.html
