[mapguide-users] Mapguide site works fine on host machine, not running properly on others
Jonathan W jwitcoski at tycotelecom.com
Tue Apr 14 09:25:54 EDT 2009
I have just started to use mapguide, Great program!!
I have downloaded the google earth sample and loaded it to my machine (localhost)
http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php
I had to change a line of code to make the thing work:  header('Content-type: application/vnd.google-earth.kml+xml'); thanks to a previous post
http://n2.nabble.com/Google-Earth-and-MapGuide-Example-td1817668.html#a1817668
I have also changed the server name in various parts of the code files
The sample works perfectly on my machine but when I try to run it from another machine within our secure network the KMLContentFactory.php does not generate a KML file. (the rest of mapguide works fine thou)
I have also turned a few layers on for a WMS server.  It works great on my computer but when I try another machine it tells me that a WMS server is there but it refuses to actually display anything.
Has anyone encountered this problem before? I have set my permissions for the mapguide folder to be readable and writeable to everyone.  I am using IIS on a Windows XP computer.  Any ideas? Is it something with the server I am running or with the code in mapguide?
View this message in context: http://n2.nabble.com/Mapguide-site-works-fine-on-host-machine%2C-not-running-properly-on-others-tp2633065p2633065.html
