[mapguide-users] Mapguide 2.1 installer
Berdel, Brian brian.berdel at mcmtrans.com
Wed Apr 15 13:07:36 EDT 2009
Thanks, I uploaded the  log to #958
The extensions fcgi and php are ok.  I think they are the only two correct?
Fcgi was pointing to www\mapagent\isapi_MapAgent.dll , but just to test I pointed it directly to
"C:\Program Files\OSGeo\MapGuide Web\www\mapagent\isapi_MapAgent.dll"
Php to
"C:\Program Files\OSGeo\MapGuide Web\Php\php5isapi.dll"
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, April 15, 2009 11:52 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Mapguide 2.1 installer
Hi Brian,
The .json mime type was something I noticed and then forgot to fix.  I've added a ticket for this (#965).
Can you please do the following on your XP platform and send me the output (or, better yet, attach it to ticket #958)
- Use 7zip to open the installer executable, and extract MapGuideOpenSource-2.1.0-Unofficial.msi from the $TEMP directory
- Run this installer from the command line as:
   msiexec /i MapGuideOpenSource-2.1.0-Unofficial.msi /l*v instlog.txt
This will let us see if something isn't installing properly anyway.  Could you also go into IIS and check all of the extension mappings in the admin directory to make sure that something isn't pointing to the wrong location?
The IIS7 installer has a number of defects (in our use case, where we want to allow the user to specify install location), and is being entirely rewritten.
Jason
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
