[mapguide-users] Mapguide 2.1 installer
Jason Birch
Jason.Birch at nanaimo.ca
Wed Apr 15 11:51:56 EDT 2009
Hi Brian,
The .json mime type was something I noticed and then forgot to fix. I've added a ticket for this (#965).
Can you please do the following on your XP platform and send me the output (or, better yet, attach it to ticket #958)
- Use 7zip to open the installer executable, and extract MapGuideOpenSource-2.1.0-Unofficial.msi from the $TEMP directory
- Run this installer from the command line as:
msiexec /i MapGuideOpenSource-2.1.0-Unofficial.msi /l*v instlog.txt
This will let us see if something isn't installing properly anyway. Could you also go into IIS and check all of the extension mappings in the admin directory to make sure that something isn't pointing to the wrong location?
The IIS7 installer has a number of defects (in our use case, where we want to allow the user to specify install location), and is being entirely rewritten.
Jason
