[mapguide-users] Mapguide 2.1 installer
Berdel, Brian
brian.berdel at mcmtrans.com
Wed Apr 15 10:07:07 EDT 2009
My Findings for 2.1 installation so far
I did not have any problems installing or with the Visual C++ Runtime Libraries, but I have been unable to get it to function properly on XP SP3 or XP SP2 with IIS / .NET.
Cannot connect via studio or maestro and cannot connect to site admin either. Keep getting specified module cannot be found, so it may be a PHP issue.
But I have checked environment variables, php extensions, etc. and they all seem to be correct.
I have tried this on multiple PC's that have all had mapguide installed before (but I removed before the install). I have not been able to try on a "clean" XP machine yet.
Everything does seem to work on server 2003 / IIS6 that did not previously have any php or mapguide on it.
On 2008 / IIS7 the installer did not add .json as a mime type and I had to make mapadmin an application to get admin page to work. I was able to load package after that, but map does not show up in sample for fusion. Here is the error in Firebug
Fusion Error: FATAL: xml2json: invalid XML document: Not Found : http://ftwvm01a/mapguide/mapagent/mapagent.fcgi?version=1.0.0&locale=en&clientagent=Fusion%20Viewer&operation=QUERYMAPFEATURES&session=420ee570-0bf4-102c-8000-000c293b52a6_en_7F0000010AFC0AFB0AFA&mapname=Sheboygan49e5e96d1f418&geometry=POLYGON((-87.75599570865604%2043.75353268191621%2C%20-87.75599570865604%2043.75274367171776%2C%20-87.75520669845758%2043.75274367171776%2C%20-87.75520669845758%2043.75353268191621%2C%20-87.75599570865604%2043.75353268191621))&maxFeatures=1&persist=0&selectionVariant=INTERSECTS&layerNames=Parcels&layerAttributeFilter=5
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo
Sent: Tuesday, April 14, 2009 12:09 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide 2.1 installer
Jackie,
Windows XP Pro SP2 x86
I have installed it correctly now
Deleted all my c:\docs sets\user\temp\*.*
Downloaded and installed vcredist_x86.exe (2008) and vcredist_x86.exe (2008 sp1)
run install again and it worked.
What may have happened prior to install.
1. in the current users temp directory a copy of vcredist_x86.exe already exists (2005 version)
2. MapGuide runs through installation, during install finds that it requires a missing "Visual C++ Runtime Libraries (x86)" then proceeds to copy file to users temp dir where a previous copy already exists?
3. Does not overwrite with the new copy, install then tries to verify vcredist_x86.exe and finds it is the wrong version.
4. Installation is stopped.
Might just have been my bad luck and un-clean system :0
I could try and remove the "c(x86)" 2008 and try again just using the installer and grab the installation log.
What is your environment? (Operating System / 32 or 64-bit). Can we get more detailed (error) information?
The installer has a Visual C++ 2008 Runtime installer built-in, and it will install that if it could not find said library on your machine.
- Jackie
Howdy,
Just downloaded and installed the mapguide 2.1 beta installer(MapGuideOpenSource-2.1.0-Unofficial-c.exe), run into an error regarding "Visual C++ Runtime Libraries (x86)" the install proceeds as if to install "Visual C++ Runtime Libraries (x86)" but fails?
Have I got the right version of the installer?
Should I have already installed "Visual C++ Runtime Libraries (x86)"?
I will try and install "Visual C++ Runtime Libraries (x86)" by itself and try the installer again.
View this message in context: http://n2.nabble.com/Mapguide-2.1-installer-tp2630990p2631108.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
