[mapguide-users] re; mapguide fusion
girish kumar bv girish778 at rediffmail.com
Tue Apr 14 13:41:15 EDT 2009
Hi,I am using Mapguide 2.0.2., created a flexible web layout in fusion.1.  How do u display google maps in flexible web layout created2.  How do u overlay the mapguide map over google maps in fusion(flexible web layout)3.  Can we use java for server side coding in fusion4.    in our application we use to make a selection of districts on the map by querying  sing selection.xml, but this operation seems to not work in fusion but this works in mapguide 20085.  In Mapguide 1.2 it was possible to generate a temporary themed layer                   using marker.xml, but this operation seems to not work in fusion6.  I have my code written in java for querying, however this seems not to work in fusion, does fusion support java7.  Using the basic web layout also in Mapguide studio 2010 i am not able to make a selection on the map or create a marker layer using marker.xmlAny help is appreciated, for the above mentioned problems.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090414/15d551b9/attachment.html
