[mapguide-users] Select points problem
Jackie Ng jumpinjackie at gmail.com
Thu Apr 16 22:08:09 EDT 2009
Have you defined a primary key for that point table?
- Jackie
Check that the datasource has a X, Y and Z value even if it only requires an X, Y just assign one of the X, Y columns to the Z and retry, had this problem a while ago and this seemed to fix it.
Good luck
I try this:
MDSYS.SDO_GEOMETRY(
            2001,
            NULL,
            MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LATITUDE),
            NULL,
            NULL)
and this:
MDSYS.SDO_GEOMETRY(
            2001,
            NULL,
            MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LONGITUDE),
            NULL,
            NULL)
but nothing happens
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2644265.html
