[mapguide-users] Select points problem
Big Tom
luizftom at gmail.com
Fri Apr 17 07:24:36 EDT 2009
Have you defined a primary key for that point table?
- Jackie
Check that the datasource has a X, Y and Z value even if it only requires an X, Y just assign one of the X, Y columns to the Z and retry, had this problem a while ago and this seemed to fix it.
Good luck
I try this:
MDSYS.SDO_GEOMETRY(
2001,
NULL,
MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LATITUDE),
NULL,
NULL)
and this:
MDSYS.SDO_GEOMETRY(
2001,
NULL,
MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE, ARE_LONGITUDE),
NULL,
NULL)
but nothing happens
Yeap, the table has a PK.
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2645220.html
