[mapguide-users] KingOracle dataconnection problem: Maestro/Studio - Property-Value fileds empty
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Apr 17 04:11:18 EDT 2009
That usually happens when MapGuide fails to load the provider.
The usual cause for this is a missing dll dependency (did you install
the oracle client?).
To resolve it, try opening the SL-King dll with DependencyWalker,
or run MapGuide in commandline mode.
Regards, Kenneth Skovhede, GEOGRAF A/S
Bojan Franc @ FER skrev:
> Problem with KingOracle connection...
> I was moving my MGOS from an old server to a new one. Both have the
> same OS (Win2008 x64) with the same MGOS 2.0.2 and KingOracle 0.8.5.
> On the old server everything works great, but on the new, I have problems.
> When making a "New Dataconnection" in MapGuide Maestro or Autodesk
> MapGuide Studio 2009, it opens the tab "New resource".
> In the Provider window I get 1 empty pair of "Property" - "Value". The
> "Property" field is blank and I can't input the username, password,
> service, etc.
> If I write into the "Value" fileds, after inputing something to the
> 2nd field, I get the error "Value column 'Property' is constrained to
> be unique. Value '' is already present. Do you want to correnct this
> value?"
> On the old server, I get the Properties list (username, password,
> service, srid, etc.) and I can input Values and connect.
> Regards,
>                 Bojan
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090417/0715b506/attachment.html
