[mapguide-users] KingOracle dataconnection problem: Maestro/Studio
- Property-Value fileds empty
Bojan Franc at FER
bojan.franc at fer.hr
Fri Apr 17 03:49:38 EDT 2009
Problem with KingOracle connection...
I was moving my MGOS from an old server to a new one. Both have the same OS (Win2008 x64) with the same MGOS 2.0.2 and KingOracle 0.8.5.
On the old server everything works great, but on the new, I have problems.
When making a "New Dataconnection" in MapGuide Maestro or Autodesk MapGuide Studio 2009, it opens the tab "New resource".
In the Provider window I get 1 empty pair of "Property" - "Value". The "Property" field is blank and I can't input the username, password, service, etc.
If I write into the "Value" fileds, after inputing something to the 2nd field, I get the error "Value column 'Property' is constrained to be unique. Value '' is already present. Do you want to correnct this value?"
On the old server, I get the Properties list (username, password, service, srid, etc.) and I can input Values and connect.
Regards,
Bojan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090417/c571424b/attachment.html
