[mapguide-users] select the location on map
Stefan Dalakov
s.dalakov at mapware.net
Fri Apr 24 06:54:23 EDT 2009
You could use something like this (executed when window.php is loaded)
document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
Stefan
susan Daniel wrote:
> hi..all
> Then what i have to do?Any solution to pass these sessionId and
> mapname ????
> regards
> susan
> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net
> <mailto:s.dalakov at mapware.net>> wrote:
> These javascript.functions never get executed. I checked now, I
> added some "alert"s and they didn't show.
> susan Daniel wrote:
>> HI..
>> I removed that brace but still the error is there
>> regards
>> susan
>> On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>> <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
>> I see an extra brace (the very first one) in the javascript
>> block that could
>> be messing everything up.
>> - Jackie
>> SusanDaniel wrote:
>> > hi all
>> > In order to display a form in the task pane i've
>> the following
>> > code
>> > in "....../mapviewerphp/window.php"
>> > <body>
>> > <script language="javascript">
>> > function getsession()
>> > sessionId=parent.parent.mapframe.GetSessionId();
>> > function getmapname()
>> > mapname=parent.parent.mapframe.GetMapName();
>> > </script>
>> > <form action="selectlocation.php" method="get">
>> > Enter PanId <input type="text" name="PanId"/><br><br>
>> > <input type="hidden"name="SESSION"
>> value="javascript:getsession()"/ >
>> > <input type="hidden"name="MAPNAME"
>> value="javascript:getmapname()"/ >
>> > <input type="submit" value="Submit" />
>> > </form>
>> > *and in the selectlocation .php i am having
>> > </head>
>> > <?php $ID= $_GET['PanId'];
>> > ?>.<br />
>> > <body class="AppFrame" onLoad="OnPageLoad()">
>> > <h1 class="AppHeading">Select features</h1>
>> > <?php
>> > include '../common/common.php';
>> > $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>> $_GET;
>> > $sessionId = $args['SESSION'];
>> > $mapName = $args['MAPNAME'];
>> > try
>> > // Initialize the Web Extensions and connect to the
>> Server using
>> > // the Web Extensions session identifier stored in
>> PHP session
>> > state.
>> > MgInitializeWebTier ($webconfigFilePath);
>> > $userInfo = new MgUserInformation($sessionId);
>> > $siteConnection = new MgSiteConnection();
>> > $siteConnection->Open($userInfo);
>> > $map = new MgMap($siteConnection);
>> > $map->Open($mapName);
>> > // Get the geometry for the boundaries of District 1
>> > $districtQuery = new MgFeatureQueryOptions();
>> > $districtQuery->SetFilter("pan_id==$ID");
>> > $layer = $map->GetLayers()->GetItem('Panchayat');
>> > $featureReader = $layer->SelectFeatures($districtQuery);
>> > $featureReader->ReadNext();
>> > $districtGeometryData = $featureReader->
>> > GetGeometry('Data');
>> > // Convert the AGF binary data to MgGeometry.
>> > $agfReaderWriter = new MgAgfReaderWriter();
>> > $districtGeometry =
>> $agfReaderWriter->Read($districtGeometryData);
>> > // Create a filter to select the desired features.
>> Combine
>> > // a basic filter and a spatial filter.
>> > $queryOptions = new MgFeatureQueryOptions();
>> > $queryOptions->SetSpatialFilter('SHPGEOM',
>> $districtGeometry,
>> > MgFeatureSpatialOperations::Inside);
>> > // Get the features from the feature source,
>> > // turn it into a selection, then save the selection
>> as XML.
>> > $layer = $map->GetLayers()->GetItem(0);
>> > $featureReader = $layer->SelectFeatures($queryOptions);
>> > $selection = new MgSelection($map);
>> > $selection->AddFeatures($layer, $featureReader, 0);
>> > $selectionXml = $selection->ToXml();
>> > catch (MgException $e)
>> > echo $e->GetMessage();
>> > echo $e->GetDetails();
>> > </body>
>> > function OnPageLoad()
>> > selectionXml = '<?php echo $selectionXml; ?>';
>> > parent.parent.SetSelectionXML(selectionXml);
>> > </script>
>> > </body>
>> > </html>
>> > *This code..But when i enter the panId in the form this
>> error is occuring
>> > Invalid argument(s): [1] = "javascript:getsession()" The
>> session ID is
>> > invalid because the session separator character was not
>> found.Invalid
>> > argument(s): [1] = "javascript:getsession()" The session ID
>> is invalid
>> > because the session separator character was not found.
>> Exception occurred
>> > in
>> > method MgUserInformation.SetMgSessionId at line 183 in file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>> > Any mistake in my coding?????
>> > Help me plss
>> > regards
>> > susan
>> > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>> > <dave.wilson at autodesk.com
>> <mailto:dave.wilson at autodesk.com>>wrote:
>> >> Did you check out the samples in the downloads area of Osgeo?
>> >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>> >> Dave
>> >> *From:* mapguide-users-bounces at lists.osgeo.org
>> <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
>> <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
>> Of *Ivan Milicevic
>> >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>> >> *To:* MapGuide Users Mail List
>> >> *Subject:* RE: [mapguide-users] select the location on map
>> >> You can get it from some of them. Please, read descritption.
>> Of *susan Daniel
>> >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>> >> *Subject:* Re: [mapguide-users] select the location on map
>> >> Thank u....
>> >> Can i get the source code of any of these
>> sample
>> >> applications? If so from where?
>> >> regards
>> >> susan
>> >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>> >> Ivan.Milicevic at supranet.hr
>> <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>> >> http://mapguide.osgeo.org/livegallery.html
>> Of *susan Daniel
>> >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>> >> hi deve
>> >> I couldn't find that sample application.Any link?
>> >> regards
>> >> susan
>> >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>> <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
>> >> wrote:
>> >> The sample application that does the Find Address does a
>> selection on the
>> >> map when you click on one of the search results. I thought
>> this was
>> >> discussed in the Sample Application.
>> >> Dave
>> Of *susan Daniel
>> >> *Sent:* Monday, April 20, 2009 12:18 AM
>> >> hi alll...........
>> >> I read the dev guide but didn't get any
>> idea regarding
>> >> this.Hav anyone tried this before pls give me any hint how
>> to start this
>> >> thanks ®ards
>> >> susan
>> >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>> >> wrote:
>> >> Have you read through the developer’s guide? It has sample
>> code for
>> >> selection and explains many concepts. It sounds like you
>> need to make
>> >> either
>> >> an invoke script or invoke url call from a command in your
>> Basic or
>> >> Flexible
>> >> Web Layout. You don’t actually have to replace the
>> gettingstarted.php. In
>> >> the invoke script or invoke url command allows you to
>> specify the target
>> >> frame for the output of the script.
>> >> Regards,
>> >> Dave
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 3:57 AM
>> >> yeah...i know that..
>> >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>> >> Did you know how to create file that display's database
>> table? If you
>> >> don't
>> >> know that you must find help somewhere else because I'm
>> not a PHP guy.
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 11:42 AM
>> >> Hi..
>> >> No i dont have the file that displays database
>> table...Actually iam
>> >> doing this prjct in php.but i know javascript'
>> >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>> >> Ok, so you have file that display's data from your
>> database table? Or you
>> >> don't have it at all? How familiar are you with javascript?
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 11:13 AM
>> >> hi...
>> >> My problem is that..
>> >> I have a database table..Having colums place ,id etc .If i
>> >> selected(clicking) a data in the table the corresponding
>> place(polygon)
>> >> should be displayed(selected) on the map...My map is a
>> polygon map .each
>> >> polygon having unique id.and the same id is present in the
>> db table
>> >> also....Now u got it?any idea please help...
>> >> regards
>> >> susan
>> >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>> >> I'm not sure that I understand your problem. With this
>> code you can
>> >> select
>> >> any feature on map. Can you send a little bit more
>> information? I'm clues
>> >> over there.
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 10:47 AM
>> >> thank you ivan...
>> >> on which file i have to write this
>> coding??? any
>> >> idea??
>> >> regards
>> >> susan
>> >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>> >> OBJEKTI is layer name and other thing is path to the
>> feature source.
>> >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>> >> You can copy/paste feature source from mapguide maestro in
>> layer
>> >> definition
>> >> window.
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 9:45 AM
>> >> thank you Ivan
>> >> but i 'd like to know on which file i want to write this
>> coding??
>> >> In ur coding OBJEKT1 is layer name right?then what is this
>> >> "Library://PROJEKTI/" + TIMgisUser +
>> "/PODACI/OBJEKTI.FeatureSource");
>> >> thanks and regards
>> >> susan
>> >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>> >> Hello Susan,
>> >> Here is C# code for selection, it's pretty same as PHP.
>> >> MgSiteConnection siteConnection = null;
>> >> InitializeWebTier();
>> >> MgUserInformation userInfo = new
>> MgUserInformation(mgSessionId);
>> >> siteConnection.Open(userInfo);
>> >> MgResourceService resourceService =
>> siteConnection.CreateService(
>> >> MgServiceType.ResourceService) as MgResourceService;
>> >> MgFeatureService featureService =
>> >> MgServiceType.FeatureService) as MgFeatureService;
>> >> MgMap map = new MgMap();
>> >> map.Open(resourceService, "1"); //opening map with
>> name „1“
>> >> MgFeatureQueryOptions queryOptionsObjekti = new
>> >> MgAgfReaderWriter geometryReaderWriter = new
>> >> MgSelection selection = new MgSelection(map);
>> >> //Defining layer and feature source
>> >> MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>> >> MgResourceIdentifier featureResIdObjekti = new
>> MgResourceIdentifier(
>> >> //Creating feature filter, this is very important step!
>> >> string filter = "ID=" + idO;
>> >> queryOptionsObjekti.SetFilter(filter);
>> >> MgFeatureReader featureReaderObjekti =
>> featureService.SelectFeatures(
>> >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>> >> selection.AddFeatures(layerObjekti,
>> featureReaderObjekti, 1);
>> >> selection.Save(resourceService, "1");
>> >> StringReader stream = new StringReader(selection.ToXml());
>> >> string selectionXml = selection.ToXml();
>> >> featureReaderObjekti.Close();
>> >> map.Save();
>> >> //Here, you call javascript function and pass the
>> selection var
>> >> Response.Write("<script>select('" + selectionXml +
>> "');</script>");
>> >> //This is javascript function that set's the selection
>> from code and do
>> >> the
>> >> refresh.
>> >> function select(xml)
>> >> parent.mapFrame.SetSelectionXML(xml);
>> >> parent.mapFrame.ExecuteMapAction(10);
>> Of *susan Daniel
>> >> *Sent:* Friday, April 17, 2009 9:11 AM
>> >> *To:* mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> >> *Subject:* [mapguide-users] select the location on map
>> >> hi all
>> >> My plat form is mapguide maestro&php.I connect it
>> with mysql.Now
>> >> i
>> >> want to select the corresponding polygon on the map while
>> clicking on the
>> >> data in database.In order to display the database table in
>> the taskpane,i
>> >> removed the contents of the file "/mapviewerphp/getting
>> started .php" and
>> >> wrote my codings.then how to select the polygon?.Any one know
>> >> this????Anyone
>> >> having coding to do this???
>> >> please help me
>> >> thanks®ards
>> >> susan
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> >> thanks®ards
>> >> susan
>> > thanks®ards
>> > susan
>> View this message in context:
>> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> thanks®ards
>> susan
>> _______________________________________________ mapguide-users
>> mailing list mapguide-users at lists.osgeo.org
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> thanks®ards
> susan
