[mapguide-users] Adding map layers to a map by clients
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Apr 20 02:33:50 EDT 2009
There exists/existed a web based editor for MapGuide called WebStudio.
It had many of the things ready, such as a tree with resources, a basic
layer editor, etc.
I can't remember the license, but you can likely find a lot of items
from that code.
Since Maestro is based on System.Windows.Forms it is not easily portable
to a webpage.
You can use the MaestroAPI to communicate with MapGuide, but there is a
huge task
in building the userinterface with Javascript.
Regards, Kenneth Skovhede, GEOGRAF A/S
GordonL skrev:
> I think it would be very cool to be able to pull out the functionality from Maestro for creating Layers from existing data on the server (SHP, SDF, Oracle, etc) - from within the Map interface - there is a lot of work involved otherwise.
> Is there a way to let clients using  fusion, ajax or flexible web layouts add  map layers of interest to the map legend by selecting from a table that shows all avaialble map layers on the server?    This would allow users to view just the map layers of interest rather than seeing hundreds of layers in the legend and having to muddle through them.
> thanks
