[mapguide-users] Select points problem
Big Tom luizftom at gmail.com
Mon Apr 20 12:12:02 EDT 2009
Big Tom wrote:
> Jackie Ng wrote:
>> In Maestro, does this PK show up as the key column? If not have you set
>> it?
>> - Jackie
>> Big Tom wrote:
>>> Big Tom wrote:
>>>> Jackie Ng wrote:
>>>>> Have you defined a primary key for that point table?
>>>>> - Jackie
>>>>> Big Tom wrote:
>>>>>> Jamo wrote:
>>>>>>> Check that the datasource has a X, Y and Z value even if it only
>>>>>>> requires an X, Y just assign one of the X, Y columns to the Z and
>>>>>>> retry, had this problem a while ago and this seemed to fix it.
>>>>>>> Good luck
>>>>>> I try this:
>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>             2001,
>>>>>>             NULL,
>>>>>>             MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE,
>>>>>> ARE_LATITUDE),
>>>>>>             NULL,
>>>>>>             NULL)
>>>>>> and this:
>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>             2001,
>>>>>>             NULL,
>>>>>> ARE_LONGITUDE),
>>>>>>             NULL,
>>>>>>             NULL)
>>>>>> but nothing happens:-((
>>>> Yeap, the table has a PK.
>>>> I'm using Oracle 9i
>>> My Table:
>>>  http://n2.nabble.com/file/n2650913/screenhunter01200904171.jpg
>>> ARE_COORDENADA is SDO_GEOMETRY type and ARE_CODARE is my PK
> Table in Maestro
>  http://n2.nabble.com/file/n2651634/screenhunter01200904171.jpg
> It's ok? How can I set PK in Maestro?
Anyone?
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2664626.html
