[mapguide-users] Select points problem
Big Tom
luizftom at gmail.com
Mon Apr 27 16:18:52 EDT 2009
Big Tom wrote:
> Big Tom wrote:
>> Jackie Ng wrote:
>>> In Maestro, does this PK show up as the key column? If not have you set
>>> it?
>>> - Jackie
>>> Big Tom wrote:
>>>> Big Tom wrote:
>>>>> Jackie Ng wrote:
>>>>>> Have you defined a primary key for that point table?
>>>>>> - Jackie
>>>>>> Big Tom wrote:
>>>>>>> Jamo wrote:
>>>>>>>> Check that the datasource has a X, Y and Z value even if it only
>>>>>>>> requires an X, Y just assign one of the X, Y columns to the Z and
>>>>>>>> retry, had this problem a while ago and this seemed to fix it.
>>>>>>>> Good luck
>>>>>>> I try this:
>>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>> 2001,
>>>>>>> NULL,
>>>>>>> MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE,
>>>>>>> ARE_LATITUDE),
>>>>>>> NULL,
>>>>>>> NULL)
>>>>>>> and this:
>>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>> 2001,
>>>>>>> NULL,
>>>>>>> ARE_LONGITUDE),
>>>>>>> NULL,
>>>>>>> NULL)
>>>>>>> but nothing happens:-((
>>>>> Yeap, the table has a PK.
>>>>> I'm using Oracle 9i
>>>> My Table:
>>>> http://n2.nabble.com/file/n2650913/screenhunter01200904171.jpg
>>>> ARE_COORDENADA is SDO_GEOMETRY type and ARE_CODARE is my PK
>> Table in Maestro
>> http://n2.nabble.com/file/n2651634/screenhunter01200904171.jpg
>> It's ok? How can I set PK in Maestro?
> Anyone?
Hey guys, anyone can help me? Please... :-((
View this message in context: http://n2.nabble.com/Select-points-problem-tp2640686p2728310.html
