[mapguide-users] Select points problem
Haris Kurtagic haris at sl-king.com
Mon Apr 27 16:51:54 EDT 2009
Are you using King.Oracle provider ?
Which version of 9i are you using ?
Not easy for me to read from email bellow :).  You do have primary key
defined ?
If you are using King.Oracle you should check with Fdo2Fdo to confirm
that FDO class created from that oracle table has identity defined.
Also, one think I can remember happened to me recently for me is wrong
precision number set for dimensions in sdo_metadata table.
That too you can check that with Fdo2Fdo.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Big Tom
Sent: Monday, April 27, 2009 10:19 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Select points problem
Big Tom wrote:
> Big Tom wrote:
>> Jackie Ng wrote:
>>> In Maestro, does this PK show up as the key column? If not have you
set
>>> it?
>>> - Jackie
>>> Big Tom wrote:
>>>> Big Tom wrote:
>>>>> Jackie Ng wrote:
>>>>>> Have you defined a primary key for that point table?
>>>>>> - Jackie
>>>>>> Big Tom wrote:
>>>>>>> Jamo wrote:
>>>>>>>> Check that the datasource has a X, Y and Z value even if it
only
>>>>>>>> requires an X, Y just assign one of the X, Y columns to the Z
and
>>>>>>>> retry, had this problem a while ago and this seemed to fix it.
>>>>>>>> Good luck
>>>>>>> I try this:
>>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>>             2001,
>>>>>>>             NULL,
>>>>>>>             MDSYS.SDO_POINT_TYPE(ARE_LONGITUDE, ARE_LATITUDE,
>>>>>>> ARE_LATITUDE),
>>>>>>>             NULL,
>>>>>>>             NULL)
>>>>>>> and this:
>>>>>>> MDSYS.SDO_GEOMETRY(
>>>>>>>             2001,
>>>>>>>             NULL,
>>>>>>> ARE_LONGITUDE),
>>>>>>>             NULL,
>>>>>>>             NULL)
>>>>>>> but nothing happens:-((
>>>>> Yeap, the table has a PK.
>>>>> I'm using Oracle 9i
>>>> My Table:
>>>>  http://n2.nabble.com/file/n2650913/screenhunter01200904171.jpg
>>>> ARE_COORDENADA is SDO_GEOMETRY type and ARE_CODARE is my PK
>> Table in Maestro
>>  http://n2.nabble.com/file/n2651634/screenhunter01200904171.jpg
>> It's ok? How can I set PK in Maestro?
> Anyone?
Hey guys, anyone can help me? Please... :-((
View this message in context:
http://n2.nabble.com/Select-points-problem-tp2640686p2728310.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
