[mapguide-users] select the location on map
susan Daniel
daniel.susan6 at gmail.com
Tue Apr 21 00:16:56 EDT 2009
hi alll.....
Nobody having any idea regarding this????Using invokeUrl I
connected the mapguide with mysql database so that now the table can be
display in the taskpane..Then what i am trying to do is...on clicking each
record on the the table the corresponding polygon on the map should be
selected??
Can i do this ??I dont know how to proceed.....
If any one having any idea plsssss help me......
Thanks in advance
susan
On Mon, Apr 20, 2009 at 11:48 AM, susan Daniel <daniel.susan6 at gmail.com>wrote:
> hi alll...........
> I read the dev guide but didn't get any idea regarding
> this.Hav anyone tried this before pls give me any hint how to start this ...
> thanks ®ards
> susan
> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson <dave.wilson at autodesk.com>wrote:
>> Have you read through the developer’s guide? It has sample code for
>> selection and explains many concepts. It sounds like you need to make either
>> an invoke script or invoke url call from a command in your Basic or Flexible
>> Web Layout. You don’t actually have to replace the gettingstarted.php. In
>> the invoke script or invoke url command allows you to specify the target
>> frame for the output of the script.
>> Regards,
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
>> *Sent:* Friday, April 17, 2009 3:57 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] select the location on map
>> yeah...i know that..
>> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>> Ivan.Milicevic at supranet.hr> wrote:
>> Did you know how to create file that display's database table? If you
>> don't know that you must find help somewhere else because I'm not a PHP guy.
>> *Sent:* Friday, April 17, 2009 11:42 AM
>> Hi..
>> No i dont have the file that displays database table...Actually iam
>> doing this prjct in php.but i know javascript'
>> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>> Ok, so you have file that display's data from your database table? Or you
>> don't have it at all? How familiar are you with javascript?
>> *Sent:* Friday, April 17, 2009 11:13 AM
>> hi...
>> My problem is that..
>> I have a database table..Having colums place ,id etc .If i
>> selected(clicking) a data in the table the corresponding place(polygon)
>> should be displayed(selected) on the map...My map is a polygon map .each
>> polygon having unique id.and the same id is present in the db table
>> also....Now u got it?any idea please help...
>> regards
>> susan
>> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>> I'm not sure that I understand your problem. With this code you can select
>> any feature on map. Can you send a little bit more information? I'm clues
>> over there.
>> *Sent:* Friday, April 17, 2009 10:47 AM
>> thank you ivan...
>> on which file i have to write this coding??? any
>> idea??
>> regards
>> susan
>> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>> OBJEKTI is layer name and other thing is path to the feature source.
>> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>> You can copy/paste feature source from mapguide maestro in layer
>> definition window.
>> *Sent:* Friday, April 17, 2009 9:45 AM
>> thank you Ivan
>> but i 'd like to know on which file i want to write this coding??
>> In ur coding OBJEKT1 is layer name right?then what is this
>> "Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
>> thanks and regards
>> susan
>> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>> Hello Susan,
>> Here is C# code for selection, it's pretty same as PHP.
>> MgSiteConnection siteConnection = null;
>> InitializeWebTier();
>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>> siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService resourceService = siteConnection.CreateService(
>> MgServiceType.ResourceService) as MgResourceService;
>> MgFeatureService featureService = siteConnection.CreateService(
>> MgServiceType.FeatureService) as MgFeatureService;
>> MgMap map = new MgMap();
>> map.Open(resourceService, "1"); //opening map with name „1“
>> MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions
>> MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
>> MgSelection selection = new MgSelection(map);
>> //Defining layer and feature source
>> MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>> MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier(
>> //Creating feature filter, this is very important step!
>> string filter = "ID=" + idO;
>> queryOptionsObjekti.SetFilter(filter);
>> MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(
>> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>> selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
>> selection.Save(resourceService, "1");
>> StringReader stream = new StringReader(selection.ToXml());
>> string selectionXml = selection.ToXml();
>> featureReaderObjekti.Close();
>> map.Save();
>> //Here, you call javascript function and pass the selection var
>> Response.Write("<script>select('" + selectionXml + "');</script>");
>> //This is javascript function that set's the selection from code and do
>> the refresh.
>> function select(xml)
>> parent.mapFrame.SetSelectionXML(xml);
>> parent.mapFrame.ExecuteMapAction(10);
>> *Sent:* Friday, April 17, 2009 9:11 AM
>> *To:* mapguide-users at lists.osgeo.org
>> *Subject:* [mapguide-users] select the location on map
>> hi all
>> My plat form is mapguide maestro&php.I connect it with mysql.Now i
>> want to select the corresponding polygon on the map while clicking on the
>> data in database.In order to display the database table in the taskpane,i
>> removed the contents of the file "/mapviewerphp/getting started .php" and
>> wrote my codings.then how to select the polygon?.Any one know this????Anyone
>> having coding to do this???
>> please help me
>> thanks®ards
>> susan
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> thanks®ards
>> susan
>> thanks®ards
>> susan
>> thanks®ards
>> susan
>> thanks®ards
>> susan
>> thanks®ards
>> susan
> thanks®ards
> susan
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090421/25d2d533/attachment.html
