[mapguide-users] select the location on map
Stefan Dalakov s.dalakov at mapware.net
Tue Apr 21 03:10:26 EDT 2009
Hi Susan,
After you have displayed some rows, and they are clickable, on clicking
on a row you should (on the server side) create a selection object, add
the feature corresponding to this row  to the selection object and  send
the selection to  the viewer.  The code for this you can find in Dev
Guide - there is a chapter named "Setting the Active Selection With the
Web API" - page 53. I don't think I can explain it better, than the guys
who wrote this document.
Stefan Dalakov
susan Daniel wrote:
> hi  alll.....
>             Nobody having any idea regarding this????Using invokeUrl I
> connected the mapguide with mysql  database so that now the table can
> be display in the taskpane..Then what i am trying to do is...on
> clicking each record on the the table the corresponding polygon on the
> map should be selected??
>  Can i do this ??I dont know how to proceed.....
> If any one having any idea plsssss help me......
> Thanks in advance
> susan
> On Mon, Apr 20, 2009 at 11:48 AM, susan Daniel
> <daniel.susan6 at gmail.com <mailto:daniel.susan6 at gmail.com>> wrote:
>     hi alll...........
>                       I read the dev guide but didn't get any idea
>     regarding this.Hav anyone tried this before pls give me any hint
>     how to start this ...
>     thanks &regards
>     susan
>     On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>     <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>> wrote:
>         Have you read through the developer’s guide? It has sample
>         code for selection and explains many concepts. It sounds like
>         you need to make either an invoke script or invoke url call
>         from a command in your Basic or Flexible Web Layout. You don’t
>         actually have to replace the gettingstarted.php. In the invoke
>         script or invoke url command allows you to specify the target
>         frame for the output of the script.
>         Regards,
>         Dave
>         *From:* mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>
>         [mailto:mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf Of
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 3:57 AM
>         *To:* MapGuide Users Mail List
>         *Subject:* Re: [mapguide-users] select the location on map
>         yeah...i know that..
>         On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic
>         <Ivan.Milicevic at supranet.hr
>         <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>         Did you know how to create file that display's database table?
>         If you don't know that you must find help somewhere else
>         because I'm not a PHP guy.
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 11:42 AM
>         Hi..
>             No i dont have the file that displays database
>         table...Actually iam doing this prjct in php.but i know
>         javascript'
>         On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic
>         Ok, so you have file that display's data from your database
>         table? Or you don't have it at all? How familiar are you with
>         javascript?
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 11:13 AM
>         hi...
>            My problem is that..
>            I have a database table..Having colums  place ,id etc .If i
>         selected(clicking) a data in the table the corresponding
>         place(polygon) should be displayed(selected) on the map...My
>         map is a polygon map .each polygon having unique id.and the
>         same id is present in the db table also....Now u got it?any
>         idea please help...
>         regards
>         susan
>         On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic
>         I'm not sure that I understand your problem. With this code
>         you can select any feature on map. Can you send a little bit
>         more information? I'm clues over there.
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 10:47 AM
>         thank you  ivan...
>                                on which file i have to write this
>         coding???  any idea??
>         regards
>         susan
>         On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic
>         OBJEKTI is layer name and other thing is path to the feature
>         source.
>         "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>         You can copy/paste feature source from mapguide maestro in
>         layer definition window.
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 9:45 AM
>         thank you Ivan
>         but  i 'd like to know on which file i want to write this coding??
>         In ur coding OBJEKT1  is layer name right?then what is
>         this"Library://PROJEKTI/" + TIMgisUser +
>         "/PODACI/OBJEKTI.FeatureSource");
>         thanks and regards
>         susan
>         On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic
>         Hello Susan,
>         Here is C# code for selection, it's pretty same as PHP.
>         MgSiteConnection siteConnection = null;
>             InitializeWebTier();
>             MgUserInformation userInfo = new
>         MgUserInformation(mgSessionId);
>             siteConnection = new MgSiteConnection();
>             siteConnection.Open(userInfo);
>             MgResourceService resourceService =
>         siteConnection.CreateService(MgServiceType.ResourceService) as
>         MgResourceService;
>             MgFeatureService featureService =
>         siteConnection.CreateService(MgServiceType.FeatureService) as
>         MgFeatureService;
>             MgMap map = new MgMap();
>             map.Open(resourceService, "1"); //opening map with name „1“
>             MgFeatureQueryOptions queryOptionsObjekti = new
>         MgFeatureQueryOptions();
>             MgAgfReaderWriter geometryReaderWriter = new
>         MgAgfReaderWriter();
>             MgSelection selection = new MgSelection(map);
>             //Defining layer and feature source
>             MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>             MgResourceIdentifier featureResIdObjekti = new
>         MgResourceIdentifier("Library://PROJEKTI/" + TIMgisUser +
>             //Creating feature filter, this is very important step!
>             string filter = "ID=" + idO;
>             queryOptionsObjekti.SetFilter(filter);
>             MgFeatureReader featureReaderObjekti =
>         featureService.SelectFeatures(featureResIdObjekti, "OBJEKTI",
>         queryOptionsObjekti);
>             selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
>             selection.Save(resourceService, "1");
>             StringReader stream = new StringReader(selection.ToXml());
>             string selectionXml = selection.ToXml();
>             featureReaderObjekti.Close();
>             map.Save();
>             //Here, you call javascript function and pass the
>         selection var
>             Response.Write("<script>select('" + selectionXml +
>         "');</script>");
>         //This is javascript function that set's the selection from
>         code and do the refresh.
>         function select(xml)
>         parent.mapFrame.SetSelectionXML(xml);
>         parent.mapFrame.ExecuteMapAction(10);
>         *susan Daniel
>         *Sent:* Friday, April 17, 2009 9:11 AM
>         *To:* mapguide-users at lists.osgeo.org
>         <mailto:mapguide-users at lists.osgeo.org>
>         *Subject:* [mapguide-users] select the location on map
>         hi all
>                 My plat form is mapguide maestro&php.I connect it with
>         mysql.Now i want to select the corresponding polygon on the
>         map while clicking on the data in database.In order to display
>         the database table in the taskpane,i removed the contents of
>         the file "/mapviewerphp/getting started .php" and wrote my
>         codings.then how to select the polygon?.Any one know
>         this????Anyone having coding to do this???
>         please help me
>         thanks&regards
>          susan
>         _______________________________________________
>         mapguide-users mailing list
>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>         thanks&regards
>          susan
>         thanks&regards
>          susan
>         thanks&regards
>          susan
>         thanks&regards
>          susan
>         thanks&regards
>          susan
>     thanks&regards
>      susan
> thanks&regards
>  susan
