[mapguide-users] Problem loading raster (TIF) files
psciga scigalla at battefeld.com
Tue Apr 21 03:50:35 EDT 2009
Hi Kenneth and Zac,
thank yo for your response.
Kenneth Skovhede, GEOGRAF A/S wrote:
> There are some general troubleshooting tips for rasters here:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Try the part labeled "Debugging Rasters in MapGuide".
Yes, thank you, I tried it. Here the protocol:
C:\Programme\MapGuideOpenSource2.0\Server\Bin>set CPL_DEBUG=on
C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver stop
Stopping the server service.
C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver run
Running the server interactively as an application instead of as a service.
(5928) Server starting...
(5928) PROJ4 Coordinate System Library
(5928) Server started.
GDAL: Auto register
C:\Programme\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gd
al_MrSID.dll using GDALRegister_MrSID.
GDAL: GDALOpen(C:\loeschen2/261801.TIF) succeeds as GTiff.
For this test, I used a new directory path with only one tif to exclude
other infuences. Is there something irregular?
zspitzer wrote:
> There is a patch for 2.0.2 which makes GDAL stable....
It sounds very good. But I'm not sure if I can do this update from 2.0.1 to
2.0.2. If I remember right, 2.0.2 comes with a PHP version unlike
5.2.5?????? I need 5.2.5, because our database is Sybase SQL Anywhere 9. And
this version uses exactly PHP 525.
Have you any suggestions for a newbie in programming, how to make it without
troubles?
Regards - Peter
View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2668518.html
