[mapguide-users] Problem loading raster (TIF) files
    Zac Spitzer
    zac.spitzer at gmail.com
    Tue Apr 21 04:02:49 EDT 2009
i'm pretty sure php didn't change between 2.0.1 and 2.0.2
the good news is there has been a lot of effort round rasters in 2.1
and they should "just work"
rasters had a tendancy to crash mapguide in 2.0.x, which *may* explain the
empty result
On Tue, Apr 21, 2009 at 5:50 PM, psciga <scigalla at battefeld.com> wrote:
> Hi Kenneth and Zac,
> thank yo for your response.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There are some general troubleshooting tips for rasters here:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>> Try the part labeled "Debugging Rasters in MapGuide".
> Yes, thank you, I tried it. Here the protocol:
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>set CPL_DEBUG=on
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver stop
> Stopping the server service.
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver run
> Running the server interactively as an application instead of as a service.
> (5928) Server starting...
> (5928) PROJ4 Coordinate System Library
> (5928) Server started.
> GDAL: Auto register
> C:\Programme\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gd
> al_MrSID.dll using GDALRegister_MrSID.
> GDAL: GDALOpen(C:\loeschen2/261801.TIF) succeeds as GTiff.
> For this test, I used a new directory path with only one tif to exclude
> other infuences. Is there something irregular?
> zspitzer wrote:
>> There is a patch for 2.0.2 which makes GDAL stable....
> It sounds very good. But I'm not sure if I can do this update from 2.0.1 to
> 2.0.2. If I remember right, 2.0.2 comes with a PHP version unlike
> 5.2.5?????? I need 5.2.5, because our database is Sybase SQL Anywhere 9. And
> this version uses exactly PHP 525.
> Have you any suggestions for a newbie in programming, how to make it without
> troubles?
> Regards - Peter
> View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2668518.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
