[mapguide-users] Problem loading raster (TIF) files
psciga
scigalla at battefeld.com
Tue Apr 21 04:13:07 EDT 2009
Thanky you!
You gives me the courage, to try an update. I'll give a report what happens.
Regards - Peter
zspitzer wrote:
> i'm pretty sure php didn't change between 2.0.1 and 2.0.2
> the good news is there has been a lot of effort round rasters in 2.1
> and they should "just work"
> rasters had a tendancy to crash mapguide in 2.0.x, which *may* explain the
> empty result
> On Tue, Apr 21, 2009 at 5:50 PM, psciga <scigalla at battefeld.com> wrote:
>> Hi Kenneth and Zac,
>> thank yo for your response.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> There are some general troubleshooting tips for rasters here:
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>>> Try the part labeled "Debugging Rasters in MapGuide".
>> Yes, thank you, I tried it. Here the protocol:
>> C:\Programme\MapGuideOpenSource2.0\Server\Bin>set CPL_DEBUG=on
>> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver stop
>> Stopping the server service.
>> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver run
>> Running the server interactively as an application instead of as a
>> service.
>> (5928) Server starting...
>> (5928) PROJ4 Coordinate System Library
>> (5928) Server started.
>> GDAL: Auto register
>> C:\Programme\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gd
>> al_MrSID.dll using GDALRegister_MrSID.
>> GDAL: GDALOpen(C:\loeschen2/261801.TIF) succeeds as GTiff.
>> For this test, I used a new directory path with only one tif to exclude
>> other infuences. Is there something irregular?
>> zspitzer wrote:
>>> There is a patch for 2.0.2 which makes GDAL stable....
>> It sounds very good. But I'm not sure if I can do this update from 2.0.1
>> to
>> 2.0.2. If I remember right, 2.0.2 comes with a PHP version unlike
>> 5.2.5?????? I need 5.2.5, because our database is Sybase SQL Anywhere 9.
>> And
>> this version uses exactly PHP 525.
>> Have you any suggestions for a newbie in programming, how to make it
>> without
>> troubles?
>> Regards - Peter
>> View this message in context:
>> http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2668518.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2668608.html
