[mapguide-users] Problem loading raster (TIF) files
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Apr 21 05:34:40 EDT 2009
There should be some extent information following the last line in your
output.
Check if those extents are what you expect them to be.
Also check the error log:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
Regards, Kenneth Skovhede, GEOGRAF A/S
psciga skrev:
> Yes, thank you, I tried it. Here the protocol:
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>set CPL_DEBUG=on
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver stop
> Stopping the server service.
> C:\Programme\MapGuideOpenSource2.0\Server\Bin>mgserver run
> Running the server interactively as an application instead of as a service.
> (5928) Server starting...
> (5928) PROJ4 Coordinate System Library
> (5928) Server started.
> GDAL: Auto register
> C:\Programme\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gd
> al_MrSID.dll using GDALRegister_MrSID.
> GDAL: GDALOpen(C:\loeschen2/261801.TIF) succeeds as GTiff.
> For this test, I used a new directory path with only one tif to exclude
> other infuences. Is there something irregular?
