[mapguide-users] Problem loading raster (TIF) files
Zac Spitzer zac.spitzer at gmail.com
Tue Apr 21 07:53:44 EDT 2009
see http://n2.nabble.com/Urgent-MGOS-stability-problem-tp2508362p2526257.html
On Tue, Apr 21, 2009 at 9:46 PM, psciga <scigalla at battefeld.com> wrote:
> Meanwhile I have done the following steps on a VM machine (XP SP2):
> 1. downloaded MGOS and extensions 2.0.2
> 2. uninstalled MGOS(&extensions) 2.0.1
> 2. installed MGOS 2.0.2 (yes, PHP is the same 5.2.5 --- thanks Zac)
> 3. installed (copied) MrSID as described in FdoGdalNotes (are there any
> other patches???)
> 4. loaded the package of my  single TIF example
> The behavior is the same as before. The error log is empty.
> Kenneth, what do you meen with ...
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There should be some extent information following the last line in your
>> output.
>> Check if those extents are what you expect them to be.
> I can only start the Server with mgserver run. But the once way (for me) to
> stop it is to close the DOS window? Is there an other possibility? Because
> when I do it in this way, I can't see following lines.
> Sorry, I know it seems a bit silly.
> Regards - Peter
> View this message in context: http://n2.nabble.com/Problem-loading-raster-%28TIF%29-files-tp2664565p2669490.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
