[mapguide-users] can anyone solved this buffer problem
padmini godavarthi
godavarthi.padmini at gmail.com
Wed Apr 22 08:11:04 EDT 2009
Thanks for ur reply
u man to say in mapdefinition(in maestro)????????????????
iam using maestro and i have selected the coordinate system as
http://n2.nabble.com/file/n2675676/coor.jpeg
does i did any thing wrong???????????????
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Have you tried to add a coordinate system override,
> using Maestro or Studio?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>> i want to make a buffer to my data
>> the buffer function works fine for this sheboygan data but not for my
>> data
>> i have debugged the application and i got the error at
>> MgResourceIdentifier featSourceId = new
>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>> MgSpatialContextReader ctxs =
>> featureSrvc.GetSpatialContexts(featSourceId, false);
>> String srsDefDs = "";
>> if (ctxs != null && ctxs.ReadNext())
>> srsDefDs = ctxs.GetCoordinateSystemWkt();
>> In Sheboygan data
>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>> but for my data
>> srsDefDs comes as null
>> Actually my data is in coordinate system
>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>> can u plz tell me the solution????????????????????????
>> plzzz
>> Regards,
>> Padmini.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2675676.html
