[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Apr 22 08:56:58 EDT 2009
No, I meant "Coordinate System Override", which is located on the
FeatureSource editor at the bottom.
See screenshots here:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks for ur reply
> u man to say in mapdefinition(in maestro)????????????????
> iam using maestro and i have selected  the coordinate system as
> http://n2.nabble.com/file/n2675676/coor.jpeg
> does i did any thing wrong???????????????
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Have you tried to add a coordinate system override,
>> using Maestro or Studio?
>>>  Hi,
>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>> i want to make a buffer to my data
>>> the buffer function works fine for this sheboygan data but not for my
>>> data
>>> i have debugged the application and i got the error at
>>>     MgResourceIdentifier featSourceId = new
>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>             MgSpatialContextReader ctxs =
>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>             String srsDefDs = "";
>>>             if (ctxs != null && ctxs.ReadNext())
>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>> In Sheboygan data
>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>> but for my data
>>>   srsDefDs comes as null
>>> Actually my data is in coordinate system
>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>> can u plz tell me the solution????????????????????????
>>> plzzz
>>> Regards,
>>> Padmini.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090422/7e5d005d/attachment.html
