[mapguide-users] can anyone solved this buffer problem
padmini godavarthi
godavarthi.padmini at gmail.com
Wed Apr 22 09:06:15 EDT 2009
thanks but is it necessary overriding a coordinate system????????
How it willbe done???????
can u provide me some guidance???????
i have seen ur link but no data available in that for overrides coordinate
system
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
can u plz tell me????????????
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> No, I meant "Coordinate System Override", which is located on the
> FeatureSource editor at the bottom.
> See screenshots here:
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for ur reply
>> u man to say in mapdefinition(in maestro)????????????????
>> iam using maestro and i have selected the coordinate system as
>> http://n2.nabble.com/file/n2675676/coor.jpeg
>> does i did any thing wrong???????????????
>> Regards,
>> Padmini.
>>> Have you tried to add a coordinate system override,
>>> using Maestro or Studio?
>>>> Hi,
>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>> i want to make a buffer to my data
>>>> the buffer function works fine for this sheboygan data but not for my
>>>> data
>>>> i have debugged the application and i got the error at
>>>> MgResourceIdentifier featSourceId = new
>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>> MgSpatialContextReader ctxs =
>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>> String srsDefDs = "";
>>>> if (ctxs != null && ctxs.ReadNext())
>>>> srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>> In Sheboygan data
>>>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>> but for my data
>>>> srsDefDs comes as null
>>>> Actually my data is in coordinate system
>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>> can u plz tell me the solution????????????????????????
>>>> plzzz
>>>> Regards,
>>>> Padmini.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2676009.html
