[mapguide-users] can anyone solved this buffer problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Apr 22 09:19:30 EDT 2009
but i did it as per ur instruction but it didn't come
http://n2.nabble.com/file/n2676097/over.jpeg
my code as same as previous
 MgResourceIdentifier featSourceId = new
MgResourceIdentifier(selLayer.GetFeatureSourceId());
            MgSpatialContextReader ctxs =
featureSrvc.GetSpatialContexts(featSourceId, false);
            String srsDefDs = "";
            if (ctxs != null && ctxs.ReadNext())
      srsDefDs = ctxs.GetCoordinateSystemWkt();
in  srsDefDs i got null
does i did any thing wrong
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Yes, your FeatureSource reports an empty coordinate system, so you have
> to specify it manually.
> There is a short explanation on how to use overrides here:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> thanks but is it necessary overriding a coordinate system????????
>> How it willbe done???????
>> can u provide me some guidance???????
>> i have seen ur link but no data available in that for overrides
>> coordinate
>> system
>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>> can u plz tell me????????????
>> Regards,
>> Padmini.
>>> No, I meant "Coordinate System Override", which is located on the
>>> FeatureSource editor at the bottom.
>>> See screenshots here:
>>>> Hi,
>>>> Thanks for ur reply
>>>> u man to say in mapdefinition(in maestro)????????????????
>>>> iam using maestro and i have selected  the coordinate system as
>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>> does i did any thing wrong???????????????
>>>> Regards,
>>>> Padmini.
>>>>> Have you tried to add a coordinate system override,
>>>>> using Maestro or Studio?
>>>>>>  Hi,
>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>> i want to make a buffer to my data
>>>>>> the buffer function works fine for this sheboygan data but not for my
>>>>>> data
>>>>>> i have debugged the application and i got the error at
>>>>>> In Sheboygan data
>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>> but for my data
>>>>>>   srsDefDs comes as null
>>>>>> Actually my data is in coordinate system
>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>> can u plz tell me the solution????????????????????????
>>>>>> plzzz
>>>>>> Regards,
>>>>>> Padmini.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2676097.html
