[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Apr 22 09:23:05 EDT 2009
IIRC Shape files consist of more than just the SHP file.
You must upload all the "Properties.*" files to the datasource,
even if the upload file dialog is misleading (you must select "All
files" to see them).
A ticket for this problem is here.
http://trac.osgeo.org/mapguide/ticket/783
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> but i did it as per ur instruction but it didn't come
> http://n2.nabble.com/file/n2676097/over.jpeg
> my code as same as previous
> MgResourceIdentifier featSourceId = new
> MgResourceIdentifier(selLayer.GetFeatureSourceId());
> MgSpatialContextReader ctxs =
> featureSrvc.GetSpatialContexts(featSourceId, false);
> String srsDefDs = "";
> if (ctxs != null && ctxs.ReadNext())
> srsDefDs = ctxs.GetCoordinateSystemWkt();
> in srsDefDs i got null
> does i did any thing wrong
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Yes, your FeatureSource reports an empty coordinate system, so you have
>> to specify it manually.
>> There is a short explanation on how to use overrides here:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>> Hi,
>>> thanks but is it necessary overriding a coordinate system????????
>>> How it willbe done???????
>>> can u provide me some guidance???????
>>> i have seen ur link but no data available in that for overrides
>>> coordinate
>>> system
>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>> can u plz tell me????????????
>>> Regards,
>>> Padmini.
>>>> No, I meant "Coordinate System Override", which is located on the
>>>> FeatureSource editor at the bottom.
>>>> See screenshots here:
>>>>> Hi,
>>>>> Thanks for ur reply
>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>> iam using maestro and i have selected the coordinate system as
>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>> does i did any thing wrong???????????????
>>>>> Regards,
>>>>> Padmini.
>>>>>> Have you tried to add a coordinate system override,
>>>>>> using Maestro or Studio?
>>>>>>> Hi,
>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>> i want to make a buffer to my data
>>>>>>> the buffer function works fine for this sheboygan data but not for my
>>>>>>> data
>>>>>>> i have debugged the application and i got the error at
>>>>>>> In Sheboygan data
>>>>>>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>> but for my data
>>>>>>> srsDefDs comes as null
>>>>>>> Actually my data is in coordinate system
>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>> plzzz
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090422/b0cbb718/attachment.html
