[mapguide-users] can anyone solved this buffer problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Apr 22 10:06:49 EDT 2009
Hi Keneneth,
First of all thanks for ur patience
i have uploaded all the files but i didnt get the coordinate system
    http://n2.nabble.com/file/n2676400/file.jpeg
again i did anything wrong??????????
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> IIRC Shape files consist of more than just the SHP file.
> You must upload all the "Properties.*" files to the datasource,
> even if the upload file dialog is misleading (you must select "All
> files" to see them).
> A ticket for this problem is here.
> http://trac.osgeo.org/mapguide/ticket/783
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> but i did it as per ur instruction but it didn't come
>> http://n2.nabble.com/file/n2676097/over.jpeg
>> my code as same as previous
>>  MgResourceIdentifier featSourceId = new
>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>             MgSpatialContextReader ctxs =
>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>             String srsDefDs = "";
>>             if (ctxs != null && ctxs.ReadNext())
>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>> in  srsDefDs i got null
>> does i did any thing wrong
>> Regards,
>> Padmini.
>>> Yes, your FeatureSource reports an empty coordinate system, so you have
>>> to specify it manually.
>>> There is a short explanation on how to use overrides here:
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>> Hi,
>>>> thanks but is it necessary overriding a coordinate system????????
>>>> How it willbe done???????
>>>> can u provide me some guidance???????
>>>> i have seen ur link but no data available in that for overrides
>>>> coordinate
>>>> system
>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>> can u plz tell me????????????
>>>> Regards,
>>>> Padmini.
>>>>> No, I meant "Coordinate System Override", which is located on the
>>>>> FeatureSource editor at the bottom.
>>>>> See screenshots here:
>>>>>> Hi,
>>>>>> Thanks for ur reply
>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>> iam using maestro and i have selected  the coordinate system as
>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>> does i did any thing wrong???????????????
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> Have you tried to add a coordinate system override,
>>>>>>> using Maestro or Studio?
>>>>>>>>  Hi,
>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>> i want to make a buffer to my data
>>>>>>>> the buffer function works fine for this sheboygan data but not for
>>>>>>>> my
>>>>>>>> data
>>>>>>>> i have debugged the application and i got the error at
>>>>>>>> In Sheboygan data
>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>> but for my data
>>>>>>>>   srsDefDs comes as null
>>>>>>>> Actually my data is in coordinate system
>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>> plzzz
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2676400.html
