[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Apr 22 10:17:00 EDT 2009
I'm not sure that provider is case insensitive.
Try adding the file again, but with the name "PROPERTIES.shp".
Also, try creating a folder, and place the files in the folder.
Then try to use the "External files" and point to the folder.
Also try pointing directly to the file.
When the "Test connection" is successfull, try clicking the
rightmost button in the "coordinate system override" field, and
it will show you what the provider returns as the coordinate system.
Alternatively, try using the OGR provider instead of the SHP provider.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi Keneneth,
> First of all thanks for ur patience
> i have uploaded all the files but i didnt get the coordinate system
>     http://n2.nabble.com/file/n2676400/file.jpeg
> again i did anything wrong??????????
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> IIRC Shape files consist of more than just the SHP file.
>> You must upload all the "Properties.*" files to the datasource,
>> even if the upload file dialog is misleading (you must select "All
>> files" to see them).
>> A ticket for this problem is here.
>> http://trac.osgeo.org/mapguide/ticket/783
>>> Hi,
>>> but i did it as per ur instruction but it didn't come
>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>> my code as same as previous
>>>  MgResourceIdentifier featSourceId = new
>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>             MgSpatialContextReader ctxs =
>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>             String srsDefDs = "";
>>>             if (ctxs != null && ctxs.ReadNext())
>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>> in  srsDefDs i got null
>>> does i did any thing wrong
>>> Regards,
>>> Padmini.
>>>> Yes, your FeatureSource reports an empty coordinate system, so you have
>>>> to specify it manually.
>>>> There is a short explanation on how to use overrides here:
>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>> Hi,
>>>>> thanks but is it necessary overriding a coordinate system????????
>>>>> How it willbe done???????
>>>>> can u provide me some guidance???????
>>>>> i have seen ur link but no data available in that for overrides
>>>>> coordinate
>>>>> system
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>> can u plz tell me????????????
>>>>> Regards,
>>>>> Padmini.
>>>>>> No, I meant "Coordinate System Override", which is located on the
>>>>>> FeatureSource editor at the bottom.
>>>>>> See screenshots here:
>>>>>>> Hi,
>>>>>>> Thanks for ur reply
>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>> iam using maestro and i have selected  the coordinate system as
>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>> does i did any thing wrong???????????????
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>> using Maestro or Studio?
>>>>>>>>>  Hi,
>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>> i want to make a buffer to my data
>>>>>>>>> the buffer function works fine for this sheboygan data but not for
>>>>>>>>> my
>>>>>>>>> data
>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>> In Sheboygan data
>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>> but for my data
>>>>>>>>>   srsDefDs comes as null
>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>> plzzz
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090422/a8f3ee44/attachment.html
