[mapguide-users] select the location on map
Dave Wilson
dave.wilson at autodesk.com
Wed Apr 22 11:31:23 EDT 2009
Did you check out the samples in the downloads area of Osgeo?
http://mapguide.osgeo.org/download/releases/2.0.x-samples
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan Milicevic
Sent: Wednesday, April 22, 2009 1:52 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] select the location on map
You can get it from some of them. Please, read descritption.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan Daniel
Sent: Wednesday, April 22, 2009 9:46 AM
Subject: Re: [mapguide-users] select the location on map
Thank u....
Can i get the source code of any of these sample applications? If so from where?
regards
susan
On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
http://mapguide.osgeo.org/livegallery.html
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of susan Daniel
Sent: Wednesday, April 22, 2009 8:06 AM
hi deve
I couldn't find that sample application.Any link?
regards
susan
On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>> wrote:
The sample application that does the Find Address does a selection on the map when you click on one of the search results. I thought this was discussed in the Sample Application.
Dave
Sent: Monday, April 20, 2009 12:18 AM
hi alll...........
I read the dev guide but didn't get any idea regarding this.Hav anyone tried this before pls give me any hint how to start this ...
thanks ®ards
susan
On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>> wrote:
Have you read through the developer's guide? It has sample code for selection and explains many concepts. It sounds like you need to make either an invoke script or invoke url call from a command in your Basic or Flexible Web Layout. You don't actually have to replace the gettingstarted.php. In the invoke script or invoke url command allows you to specify the target frame for the output of the script.
Regards,
Dave
Sent: Friday, April 17, 2009 3:57 AM
yeah...i know that..
On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
Did you know how to create file that display's database table? If you don't know that you must find help somewhere else because I'm not a PHP guy.
Sent: Friday, April 17, 2009 11:42 AM
Hi..
No i dont have the file that displays database table...Actually iam doing this prjct in php.but i know javascript'
On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
Ok, so you have file that display's data from your database table? Or you don't have it at all? How familiar are you with javascript?
Sent: Friday, April 17, 2009 11:13 AM
hi...
My problem is that..
I have a database table..Having colums place ,id etc .If i selected(clicking) a data in the table the corresponding place(polygon) should be displayed(selected) on the map...My map is a polygon map .each polygon having unique id.and the same id is present in the db table also....Now u got it?any idea please help...
regards
susan
On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
I'm not sure that I understand your problem. With this code you can select any feature on map. Can you send a little bit more information? I'm clues over there.
Sent: Friday, April 17, 2009 10:47 AM
thank you ivan...
on which file i have to write this coding??? any idea??
regards
susan
On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
OBJEKTI is layer name and other thing is path to the feature source.
"Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
You can copy/paste feature source from mapguide maestro in layer definition window.
Sent: Friday, April 17, 2009 9:45 AM
thank you Ivan
but i 'd like to know on which file i want to write this coding??
In ur coding OBJEKT1 is layer name right?then what is this"Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
thanks and regards
susan
On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>> wrote:
Hello Susan,
Here is C# code for selection, it's pretty same as PHP.
MgSiteConnection siteConnection = null;
InitializeWebTier();
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resourceService = siteConnection.CreateService(MgServiceType.ResourceService) as MgResourceService;
MgFeatureService featureService = siteConnection.CreateService(MgServiceType.FeatureService) as MgFeatureService;
MgMap map = new MgMap();
map.Open(resourceService, "1"); //opening map with name "1"
MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions();
MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
MgSelection selection = new MgSelection(map);
//Defining layer and feature source
MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier("Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
//Creating feature filter, this is very important step!
string filter = "ID=" + idO;
queryOptionsObjekti.SetFilter(filter);
MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
selection.Save(resourceService, "1");
StringReader stream = new StringReader(selection.ToXml());
string selectionXml = selection.ToXml();
featureReaderObjekti.Close();
map.Save();
//Here, you call javascript function and pass the selection var
Response.Write("<script>select('" + selectionXml + "');</script>");
//This is javascript function that set's the selection from code and do the refresh.
function select(xml)
parent.mapFrame.SetSelectionXML(xml);
parent.mapFrame.ExecuteMapAction(10);
Sent: Friday, April 17, 2009 9:11 AM
To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Subject: [mapguide-users] select the location on map
hi all
My plat form is mapguide maestro&php.I connect it with mysql.Now i want to select the corresponding polygon on the map while clicking on the data in database.In order to display the database table in the taskpane,i removed the contents of the file "/mapviewerphp/getting started .php" and wrote my codings.then how to select the polygon?.Any one know this????Anyone having coding to do this???
please help me
thanks®ards
susan
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090422/9d392e52/attachment.html
