[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Fri Apr 24 04:56:14 EDT 2009
hi all
        In order to display a form in the task pane i've the following code
in "....../mapviewerphp/window.php"
<body>
<script language="javascript">
function getsession()
sessionId=parent.parent.mapframe.GetSessionId();
function getmapname()
mapname=parent.parent.mapframe.GetMapName();
</script>
<form action="selectlocation.php" method="get">
Enter PanId <input type="text" name="PanId"/><br><br>
<input type="hidden"name="SESSION" value="javascript:getsession()"/ >
<input type="hidden"name="MAPNAME" value="javascript:getmapname()"/  >
<input type="submit" value="Submit" />
</form>
*and in the selectlocation .php i am having
 </head>
  <?php $ID= $_GET['PanId'];
    ?>.<br />
  <body class="AppFrame" onLoad="OnPageLoad()">
    <h1 class="AppHeading">Select features</h1>
    <?php
    include '../common/common.php';
    $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST: $_GET;
    $sessionId = $args['SESSION'];
    $mapName = $args['MAPNAME'];
    try
      // Initialize the Web Extensions and connect to the Server using
      // the Web Extensions session identifier stored in PHP session state.
      MgInitializeWebTier ($webconfigFilePath);
      $userInfo = new MgUserInformation($sessionId);
      $siteConnection = new MgSiteConnection();
      $siteConnection->Open($userInfo);
      $map = new MgMap($siteConnection);
      $map->Open($mapName);
      // Get the geometry for the boundaries of District 1
      $districtQuery = new MgFeatureQueryOptions();
      $districtQuery->SetFilter("pan_id==$ID");
      $layer = $map->GetLayers()->GetItem('Panchayat');
      $featureReader = $layer->SelectFeatures($districtQuery);
      $featureReader->ReadNext();
      $districtGeometryData = $featureReader->
      GetGeometry('Data');
      // Convert the AGF binary data to MgGeometry.
      $agfReaderWriter = new MgAgfReaderWriter();
      $districtGeometry = $agfReaderWriter->Read($districtGeometryData);
      // Create a filter to select the desired features. Combine
      // a basic filter and a spatial filter.
      $queryOptions = new MgFeatureQueryOptions();
      $queryOptions->SetSpatialFilter('SHPGEOM', $districtGeometry,
MgFeatureSpatialOperations::Inside);
      // Get the features from the feature source,
      // turn it into a selection, then save the selection as XML.
      $layer = $map->GetLayers()->GetItem(0);
      $featureReader = $layer->SelectFeatures($queryOptions);
      $selection = new MgSelection($map);
      $selection->AddFeatures($layer, $featureReader, 0);
      $selectionXml = $selection->ToXml();
    catch (MgException $e)
      echo $e->GetMessage();
      echo $e->GetDetails();
  </body>
    function OnPageLoad()
      selectionXml = '<?php echo $selectionXml; ?>';
      parent.parent.SetSelectionXML(selectionXml);
  </script>
</body>
</html>
*This code..But when i enter the panId in the form this error is occuring *
  Invalid argument(s): [1] = "javascript:getsession()" The session ID is
invalid because the session separator character was not found.Invalid
argument(s): [1] = "javascript:getsession()" The session ID is invalid
because the session separator character was not found. Exception occurred in
method MgUserInformation.SetMgSessionId at line 183 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
Any mistake in my coding?????
Help me plss
regards
susan
On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson <dave.wilson at autodesk.com>wrote:
>  Did you check out the samples in the downloads area of Osgeo?
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Ivan Milicevic
> *Sent:* Wednesday, April 22, 2009 1:52 AM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] select the location on map
> You can get it from some of them. Please, read descritption.
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
> *Sent:* Wednesday, April 22, 2009 9:46 AM
> *Subject:* Re: [mapguide-users] select the location on map
> Thank u....
>                Can i get the source code of any of these sample
> applications? If so from where?
> regards
> susan
> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
> Ivan.Milicevic at supranet.hr> wrote:
> http://mapguide.osgeo.org/livegallery.html
> *Sent:* Wednesday, April 22, 2009 8:06 AM
> hi deve
>            I couldn't find that sample application.Any link?
> regards
> susan
> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson <dave.wilson at autodesk.com>
> wrote:
> The sample application that does the Find Address does a selection on the
> map when you click on one of the search results. I thought this was
> discussed in the Sample Application.
> Dave
> *Sent:* Monday, April 20, 2009 12:18 AM
> hi alll...........
>                   I read the dev guide but didn't get any idea regarding
> this.Hav anyone tried this before pls give me any hint how to start this ...
> thanks &regards
> susan
> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson <dave.wilson at autodesk.com>
> wrote:
> Have you read through the developer’s guide? It has sample code for
> selection and explains many concepts. It sounds like you need to make either
> an invoke script or invoke url call from a command in your Basic or Flexible
> Web Layout. You don’t actually have to replace the gettingstarted.php. In
> the invoke script or invoke url command allows you to specify the target
> frame for the output of the script.
> Regards,
> Dave
> *Sent:* Friday, April 17, 2009 3:57 AM
> yeah...i know that..
> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
> Did you know how to create file that display's database table? If you don't
> know that you must find help somewhere else because I'm not a PHP guy.
> *Sent:* Friday, April 17, 2009 11:42 AM
> Hi..
>     No i dont have the file that displays database table...Actually iam
> doing this prjct in php.but i know javascript'
> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> Ok, so you have file that display's data from your database table? Or you
> don't have it at all? How familiar are you with javascript?
> *Sent:* Friday, April 17, 2009 11:13 AM
> hi...
>    My problem is that..
>    I have a database table..Having colums  place ,id etc .If i
> selected(clicking) a data in the table the corresponding place(polygon)
> should be displayed(selected) on the map...My map is a polygon map .each
> polygon having unique id.and the same id is present in the db table
> also....Now u got it?any idea please help...
> regards
> susan
> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> I'm not sure that I understand your problem. With this code you can select
> any feature on map. Can you send a little bit more information? I'm clues
> over there.
> *Sent:* Friday, April 17, 2009 10:47 AM
> thank you  ivan...
>                        on which file i have to write this coding???  any
> idea??
> regards
> susan
> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> OBJEKTI is layer name and other thing is path to the feature source.
> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> You can copy/paste feature source from mapguide maestro in layer definition
> window.
> *Sent:* Friday, April 17, 2009 9:45 AM
> thank you Ivan
> but  i 'd like to know on which file i want to write this coding??
> In ur coding OBJEKT1  is layer name right?then what is this
> "Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
> thanks and regards
> susan
> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> Hello Susan,
> Here is C# code for selection, it's pretty same as PHP.
> MgSiteConnection siteConnection = null;
>     InitializeWebTier();
>     MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>     siteConnection.Open(userInfo);
>     MgResourceService resourceService = siteConnection.CreateService(
> MgServiceType.ResourceService) as MgResourceService;
>     MgFeatureService featureService = siteConnection.CreateService(
> MgServiceType.FeatureService) as MgFeatureService;
>     MgMap map = new MgMap();
>     map.Open(resourceService, "1"); //opening map with name „1“
>     MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions
>     MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
>     MgSelection selection = new MgSelection(map);
>     //Defining layer and feature source
>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>     MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier(
>     //Creating feature filter, this is very important step!
>     string filter = "ID=" + idO;
>     queryOptionsObjekti.SetFilter(filter);
>     MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(
> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>     selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
>     selection.Save(resourceService, "1");
>     StringReader stream = new StringReader(selection.ToXml());
>     string selectionXml = selection.ToXml();
>     featureReaderObjekti.Close();
>     map.Save();
>     //Here, you call javascript function and pass the selection var
>     Response.Write("<script>select('" + selectionXml + "');</script>");
> //This is javascript function that set's the selection from code and do the
> refresh.
> function select(xml)
> parent.mapFrame.SetSelectionXML(xml);
> parent.mapFrame.ExecuteMapAction(10);
> *Sent:* Friday, April 17, 2009 9:11 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] select the location on map
> hi all
>         My plat form is mapguide maestro&php.I connect it with mysql.Now i
> want to select the corresponding polygon on the map while clicking on the
> data in database.In order to display the database table in the taskpane,i
> removed the contents of the file "/mapviewerphp/getting started .php" and
> wrote my codings.then how to select the polygon?.Any one know this????Anyone
> having coding to do this???
> please help me
> thanks&regards
>  susan
> mapguide-users mailing list
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090424/7317f34e/attachment.html
