[mapguide-users] can anyone solved this buffer problem
padmini godavarthi godavarthi.padmini at gmail.com
Thu Apr 23 07:23:57 EDT 2009
In my data
    bool arbitraryMapSrs = (srsMap.GetType() ==
MgCoordinateSystemType.Arbitrary);
arbitraryMapSrs comes as true but in sheboygan data it comes as false
        if (arbitraryMapSrs)
            mapSrsUnits = srsMap.GetUnits();
In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes as
null
so that
 if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs && (dsSrsUnits
!= mapSrsUnits)))
                excludedLayers++;
                continue;
In my data  excludedLayers comes as 1 and where as in sheboyan data this
condition fails....................
Can u plz provide me the solution?????????????
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Why do you mention packages?
> excludedLayers is incremented because the data coordinate system is not
> the same as the map coodinate system.
> Please comment on what happend when you attempted my previous suggestions.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>> Thanks for ur suggestions.
>> I have created a package using OGR provider but in the buffering i found
>> some problem that
>>      // exclude layer if:
>>             //  the map is non-arbitrary and the layer is arbitrary or
>> vice-versa
>>             //     or
>>             //  layer and map are both arbitrary but have different units
>> (dsSrsUnits != mapSrsUnits)))
>>                 excludedLayers++;
>>                 continue;
>> it gives difference to my data and sheboygan sample data
>> so that in my code  excludedLayers is incremented to 1 so i didnt get the
>> buffer features
>> can u plz tell me the solution?????????????????
>> Regards,
>> Padmini.
>>> I'm not sure that provider is case insensitive.
>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>> Also, try creating a folder, and place the files in the folder.
>>> Then try to use the "External files" and point to the folder.
>>> Also try pointing directly to the file.
>>> When the "Test connection" is successfull, try clicking the
>>> rightmost button in the "coordinate system override" field, and
>>> it will show you what the provider returns as the coordinate system.
>>> Alternatively, try using the OGR provider instead of the SHP provider.
>>>> Hi Keneneth,
>>>> First of all thanks for ur patience
>>>> i have uploaded all the files but i didnt get the coordinate system
>>>>     http://n2.nabble.com/file/n2676400/file.jpeg
>>>> again i did anything wrong??????????
>>>> Regards,
>>>> Padmini.
>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>> even if the upload file dialog is misleading (you must select "All
>>>>> files" to see them).
>>>>> A ticket for this problem is here.
>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>> Hi,
>>>>>> but i did it as per ur instruction but it didn't come
>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>> my code as same as previous
>>>>>>  MgResourceIdentifier featSourceId = new
>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>             MgSpatialContextReader ctxs =
>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>             String srsDefDs = "";
>>>>>>             if (ctxs != null && ctxs.ReadNext())
>>>>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>> in  srsDefDs i got null
>>>>>> does i did any thing wrong
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so you
>>>>>>> have
>>>>>>> to specify it manually.
>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>> Hi,
>>>>>>>> thanks but is it necessary overriding a coordinate system????????
>>>>>>>> How it willbe done???????
>>>>>>>> can u provide me some guidance???????
>>>>>>>> i have seen ur link but no data available in that for overrides
>>>>>>>> coordinate
>>>>>>>> system
>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>> can u plz tell me????????????
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>>>> No, I meant "Coordinate System Override", which is located on the
>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>> See screenshots here:
>>>>>>>>>> Hi,
>>>>>>>>>> Thanks for ur reply
>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>> iam using maestro and i have selected  the coordinate system as
>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>  Hi,
>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>> the buffer function works fine for this sheboygan data but not
>>>>>>>>>>>> for
>>>>>>>>>>>> my
>>>>>>>>>>>> data
>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>> but for my data
>>>>>>>>>>>>   srsDefDs comes as null
>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>> plzzz
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2682369.html
