[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Apr 23 08:54:16 EDT 2009
Thats because the Sheboygan data uses a true georeferenced coordinate
system,
and your data is using a non-georeferenced system, like XY-M.
Arbitrary should be understood as "non-georeferenced".
If your data is not in the same projection as the map, you cannot use
the buffer feature.
This then returns to my initial statement: "Coordinate System Override",
which can
set the data coordinate system to match the maps.
Can you please report what happened with with the suggestions I made,
regarding the coordinate system overrides?
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> In my data
>     bool arbitraryMapSrs = (srsMap.GetType() ==
> MgCoordinateSystemType.Arbitrary);
> arbitraryMapSrs comes as true but in sheboygan data it comes as false
>         if (arbitraryMapSrs)
>             mapSrsUnits = srsMap.GetUnits();
> In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes as
> null
> so that
>  if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs && (dsSrsUnits
> != mapSrsUnits)))
>                 excludedLayers++;
>                 continue;
> In my data  excludedLayers comes as 1 and where as in sheboyan data this
> condition fails....................
> Can u plz provide me the solution?????????????
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Why do you mention packages?
>> excludedLayers is incremented because the data coordinate system is not
>> the same as the map coodinate system.
>> Please comment on what happend when you attempted my previous suggestions.
>>> Hi Kenneth,
>>> Thanks for ur suggestions.
>>> I have created a package using OGR provider but in the buffering i found
>>> some problem that
>>>      // exclude layer if:
>>>             //  the map is non-arbitrary and the layer is arbitrary or
>>> vice-versa
>>>             //     or
>>>             //  layer and map are both arbitrary but have different units
>>> (dsSrsUnits != mapSrsUnits)))
>>>                 excludedLayers++;
>>>                 continue;
>>> it gives difference to my data and sheboygan sample data
>>> so that in my code  excludedLayers is incremented to 1 so i didnt get the
>>> buffer features
>>> can u plz tell me the solution?????????????????
>>> Regards,
>>> Padmini.
>>>> I'm not sure that provider is case insensitive.
>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>> Also, try creating a folder, and place the files in the folder.
>>>> Then try to use the "External files" and point to the folder.
>>>> Also try pointing directly to the file.
>>>> When the "Test connection" is successfull, try clicking the
>>>> rightmost button in the "coordinate system override" field, and
>>>> it will show you what the provider returns as the coordinate system.
>>>> Alternatively, try using the OGR provider instead of the SHP provider.
>>>>> Hi Keneneth,
>>>>> First of all thanks for ur patience
>>>>> i have uploaded all the files but i didnt get the coordinate system
>>>>>     http://n2.nabble.com/file/n2676400/file.jpeg
>>>>> again i did anything wrong??????????
>>>>> Regards,
>>>>> Padmini.
>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>>> even if the upload file dialog is misleading (you must select "All
>>>>>> files" to see them).
>>>>>> A ticket for this problem is here.
>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>> Hi,
>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>> my code as same as previous
>>>>>>>  MgResourceIdentifier featSourceId = new
>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>             MgSpatialContextReader ctxs =
>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>             String srsDefDs = "";
>>>>>>>             if (ctxs != null && ctxs.ReadNext())
>>>>>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>> in  srsDefDs i got null
>>>>>>> does i did any thing wrong
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so you
>>>>>>>> have
>>>>>>>> to specify it manually.
>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>> Hi,
>>>>>>>>> thanks but is it necessary overriding a coordinate system????????
>>>>>>>>> How it willbe done???????
>>>>>>>>> can u provide me some guidance???????
>>>>>>>>> i have seen ur link but no data available in that for overrides
>>>>>>>>> coordinate
>>>>>>>>> system
>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>> can u plz tell me????????????
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>>>> No, I meant "Coordinate System Override", which is located on the
>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>> See screenshots here:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>> iam using maestro and i have selected  the coordinate system as
>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>> Regards,
>>>>>>>>>>> Padmini.
>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>> the buffer function works fine for this sheboygan data but not
>>>>>>>>>>>>> for
>>>>>>>>>>>>> my
>>>>>>>>>>>>> data
>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==>
>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>   srsDefDs comes as null
>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090423/293e8299/attachment.html
