[mapguide-users] can anyone solved this buffer problem
padmini godavarthi
godavarthi.padmini at gmail.com
Thu Apr 23 10:11:44 EDT 2009
Hi Kenneth,
Thanku very much for ur help.............
i did the coordinate system override as per ur instructions.
It works fine
but i felt that the buffer feature is not coming accurately??
what was the problem????????????????????????????
i mean by observing closely its not an accurate circle(buffer layer).
http://n2.nabble.com/file/n2683455/pic.jpeg
2)secondly i want to retrieve the parcel_ids that are included or
intersected in the buffer layer.How is it possible ? can u send me the
sample code?????????
Thanks in advance.
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Thats because the Sheboygan data uses a true georeferenced coordinate
> system,
> and your data is using a non-georeferenced system, like XY-M.
> Arbitrary should be understood as "non-georeferenced".
> If your data is not in the same projection as the map, you cannot use
> the buffer feature.
> This then returns to my initial statement: "Coordinate System Override",
> which can
> set the data coordinate system to match the maps.
> Can you please report what happened with with the suggestions I made,
> regarding the coordinate system overrides?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> In my data
>> bool arbitraryMapSrs = (srsMap.GetType() ==
>> MgCoordinateSystemType.Arbitrary);
>> arbitraryMapSrs comes as true but in sheboygan data it comes as false
>> if (arbitraryMapSrs)
>> mapSrsUnits = srsMap.GetUnits();
>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes as
>> null
>> so that
>> if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>> (dsSrsUnits
>> != mapSrsUnits)))
>> excludedLayers++;
>> continue;
>> In my data excludedLayers comes as 1 and where as in sheboyan data this
>> condition fails....................
>> Can u plz provide me the solution?????????????
>> Regards,
>> Padmini.
>>> Why do you mention packages?
>>> excludedLayers is incremented because the data coordinate system is not
>>> the same as the map coodinate system.
>>> Please comment on what happend when you attempted my previous
>>> suggestions.
>>>> Hi Kenneth,
>>>> Thanks for ur suggestions.
>>>> I have created a package using OGR provider but in the buffering i
>>>> found
>>>> some problem that
>>>> // exclude layer if:
>>>> // the map is non-arbitrary and the layer is arbitrary or
>>>> vice-versa
>>>> // or
>>>> // layer and map are both arbitrary but have different
>>>> units
>>>> (dsSrsUnits != mapSrsUnits)))
>>>> excludedLayers++;
>>>> continue;
>>>> it gives difference to my data and sheboygan sample data
>>>> so that in my code excludedLayers is incremented to 1 so i didnt get
>>>> the
>>>> buffer features
>>>> can u plz tell me the solution?????????????????
>>>> Regards,
>>>> Padmini.
>>>>> I'm not sure that provider is case insensitive.
>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>> Also, try creating a folder, and place the files in the folder.
>>>>> Then try to use the "External files" and point to the folder.
>>>>> Also try pointing directly to the file.
>>>>> When the "Test connection" is successfull, try clicking the
>>>>> rightmost button in the "coordinate system override" field, and
>>>>> it will show you what the provider returns as the coordinate system.
>>>>> Alternatively, try using the OGR provider instead of the SHP provider.
>>>>>> Hi Keneneth,
>>>>>> First of all thanks for ur patience
>>>>>> i have uploaded all the files but i didnt get the coordinate system
>>>>>> http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>> again i did anything wrong??????????
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>>>> even if the upload file dialog is misleading (you must select "All
>>>>>>> files" to see them).
>>>>>>> A ticket for this problem is here.
>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>> Hi,
>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>> my code as same as previous
>>>>>>>> MgResourceIdentifier featSourceId = new
>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>> MgSpatialContextReader ctxs =
>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>> String srsDefDs = "";
>>>>>>>> if (ctxs != null && ctxs.ReadNext())
>>>>>>>> srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>> in srsDefDs i got null
>>>>>>>> does i did any thing wrong
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so you
>>>>>>>>> have
>>>>>>>>> to specify it manually.
>>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>> Hi,
>>>>>>>>>> thanks but is it necessary overriding a coordinate system????????
>>>>>>>>>> How it willbe done???????
>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>> i have seen ur link but no data available in that for overrides
>>>>>>>>>> coordinate
>>>>>>>>>> system
>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>>>> No, I meant "Coordinate System Override", which is located on
>>>>>>>>>>> the
>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>> See screenshots here:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>> iam using maestro and i have selected the coordinate system as
>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data but
>>>>>>>>>>>>>> not
>>>>>>>>>>>>>> for
>>>>>>>>>>>>>> my
>>>>>>>>>>>>>> data
>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees, -180
>>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>> srsDefDs comes as null
>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2683455.html
