[mapguide-users] help
saloua wakrim wakrimsaloua.wakrim at gmail.com
Mon Apr 27 09:26:49 EDT 2009
i try the following code for displaying layer wich contains line in map, so
i digitize a line, create temporary feature for this line, create a layer
wich contains it and add it to the map. it doesn't give me some error but  i
can see the line in the map (i can draw it). Please help me. the code is
following:
String dataSource = "Session:" + sessionid1 + "//" + myLayerName +
".FeatureSource";
MgResourceIdentifier dataSourceId = new MgResourceIdentifier(dataSource);
MgFeatureService featureSrvc = (MgFeatureService
)siteConnection.CreateService(MgServiceType.FeatureService);
if (DoesLayerExist(myLayerName, map) == false)
//create Feature Source
MgClassDefinition myClassDef = new MgClassDefinition();
myClassDef.SetName(myLayerName);
myClassDef.SetDescription(myLayerName + " Feature Source");
myClassDef.SetDefaultGeometryPropertyName("SHPGEOM");
MgDataPropertyDefinition prop = new MgDataPropertyDefinition("KEY");
prop.SetDataType(MgPropertyType.Int32);
prop.SetAutoGeneration(true);
prop.SetReadOnly(true);
myClassDef.GetIdentityProperties().Add(prop);
myClassDef.GetProperties().Add(prop);
prop = new MgDataPropertyDefinition("ID");
MgGeometricPropertyDefinition geomProp = new MgGeometricPropertyDefinition(
"SHPGEOM");
geomProp.SetGeometryTypes(MgFeatureGeometricType.Curve);
myClassDef.GetProperties().Add(geomProp);
MgFeatureSchema schema = new MgFeatureSchema(myLayerName + "Schema",
myLayerName + "SchemaDesc");
schema.GetClasses().Add(myClassDef);
MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56 (GDA94 / MGA
zone 56)", map.GetMapSRS(), schema);
featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
//create layer
//String layerDef = "Session:" + sessionid1 + "//" + myLayerName +
".LayerDefinition";
MgResourceIdentifier layerDefId = new MgResourceIdentifier(
"Library://essaicalque/Redline.LayerDefinition");
MgByteSource content = new MgByteSource(@"C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\essaiselect2\Layerdef.xml"
resourceSrvc.SetResource(layerDefId, content.GetReader(), null);
 //code enlev‚ d'ici: ajouter layer resource … la carte
//il faut ajouter l'autre code: add layer resource to map
//DOMDocument domdoc = new DOMdocument();
MgLayerresult=add_layer_resource_to_map(layerDefId,resourceSrvc,myLayerName,myLayerName,map);
MgInsertFeatures insertFeatures = new MgInsertFeatures(myLayerName,
makeLine("1", x0, y0, x1, y1));
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
commands.Add(insertFeatures);
int commandIndex = commands.IndexOf(insertFeatures);
MgPropertyCollection insertResults;
insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands, false);
MgLayer myLayer1 = map.GetLayers().GetItem(myLayerName) as MgLayer;
myLayer1.ForceRefresh();
//commands.Add(new MgInsertFeatures(myLayerName,makeLine("1", x0, y0, x1,
y1)));
map.Save(resourceSrvc);
<script runat=server>
Boolean result;
MgPropertyCollection makeLine(String Name, Double x0, Double y0, Double x1,
Double y1)
MgPropertyCollection PropertyCollection = new MgPropertyCollection();
MgInt32Property nameProperty = new MgInt32Property("ID", 1);
PropertyCollection.Add(nameProperty);
MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
MgGeometry geometry = wktReaderWriter.Read("LINESTRING XY (" + x0 + " " + y0
+ "," + x1 + " " + y1 + ")") as MgLineString;
//MgGeometry geometry = wktReaderWriter.Read("LINESTRING(3 4,10 50,20 25)")
as MgLineString;
 MgByteReader geometryByteReader = agfReaderWriter.Write(geometry);
MgGeometryProperty geometryProperty = new MgGeometryProperty("SHPGEOM",
geometryByteReader);
PropertyCollection.Add(geometryProperty);
return PropertyCollection;
Boolean DoesLayerExist(String LayerName, MgMap Map)
MgLayerCollection layers = Map.GetLayers();
result = (layers.Contains(myLayerName));
return result;
MgLayer add_layer_resource_to_map(MgResourceIdentifier layerresourceid,
MgResourceService rs, String layername, String layerlegendlabel, MgMap map)
MgLayer myLayer = new MgLayer(layerresourceid, rs);
myLayer.SetName(layername);
myLayer.SetLegendLabel(layerlegendlabel);
myLayer.SetDisplayInLegend(true);
myLayer.SetSelectable(true);
if (!map.GetLayers().Contains(layername))
map.GetLayers().Insert(0, myLayer);
myLayer.SetVisible(true);
myLayer.ForceRefresh();
return myLayer;
 </script>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090427/de21e96a/attachment.html
