[mapguide-users] what does maestro version is need for MGOS 2.1?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Apr 29 03:45:01 EDT 2009
Any version should work, newest is prefered.
There is a new version of the LayerDefinition which is not yet supported,
but unless you manage to make one of those, everything else should work
fine.
I just tested on MGE 2010, which should be close to 2.1, and everything
works fine there.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Hi All,
> I have installed the MGOS 2.1 (unreleased) in my test enviroment (a virtual
> machine with win 2003 SP2 + IIS6).
> The installer comes with the maestro 1.0.9.2926 version. Then I accessed to
> mapguide server using this maestro versiona and I could see the sheybogan
> sample that I had loaded previously through the mapguide admin. As soon I
> wanted to create or edit dataconnection, layerdefinition or mapdefinition,
> "the visual studio just in time debugger" is raised and next an error
> message "an error occured while saving. the underlying connection was
> closed. un expected error occurred on a receive".
> I have reviewed the mapguide server log error and I have found anything.
> Which is the suitable maestro version in order to access to MGOS 2.1?
> Another thing I could display the sheyboygan sample data using the BASIC
> LAYOUT, however I could not display it with FLEXIBLE LAYOUT. for the
> flexible layout case the browser shows the layout with empty widgets(without
> map). the map widget is waiting the response from the server all the time.
> Regards,
> RODOLFO
> Rodolfo Moreno
> CivilEng
