[mapguide-users] WFS publishing question
Chris Claydon
chris.claydon at autodesk.com
Wed Apr 29 11:26:56 EDT 2009
That's right - you need to set up the equivalent settings for the feature sources that you've set up for the layers for WMS. (WMS works with layers to return raster images, WFS works with feature sources to return vector data with no inherent stylization).
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, April 29, 2009 7:17 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] WFS publishing question
isn't WFS only via featuresources?
On Wed, Apr 29, 2009 at 11:12 PM, Dragan Podvezanec
<dragan.podvezanec at gmail.com> wrote:
> Could someone write what is exactly needed to publish layer data via WFS
> service? With Maestro (i also tried Studio, same result), I edited layer
> properties, added description, metadata, bounds, SRS and in the
> functionality I checked Available and Queryable. But none of clients "sees"
> this layer, and also with GETCAPABILITIES I don't see this layer. Only
> layers I see are those from Sheboygan example. So, what else need I do to
> publish layer with WFS? Just to mention, layer is seen through WMS service.
> View this message in context: http://n2.nabble.com/WFS-publishing-question-tp2740434p2740434.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
