[mapguide-users] WFS publishing question
Zac Spitzer
zac.spitzer at gmail.com
Wed Apr 29 11:49:58 EDT 2009
would be nice if you could use a layer as a WFS source, i kinda
expected it to be.. much more flexible control...
z
On Thu, Apr 30, 2009 at 1:26 AM, Chris Claydon
<chris.claydon at autodesk.com> wrote:
> That's right - you need to set up the equivalent settings for the feature sources that you've set up for the layers for WMS. (WMS works with layers to return raster images, WFS works with feature sources to return vector data with no inherent stylization).
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, April 29, 2009 7:17 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] WFS publishing question
> isn't WFS only via featuresources?
> On Wed, Apr 29, 2009 at 11:12 PM, Dragan Podvezanec
> <dragan.podvezanec at gmail.com> wrote:
>> Could someone write what is exactly needed to publish layer data via WFS
>> service? With Maestro (i also tried Studio, same result), I edited layer
>> properties, added description, metadata, bounds, SRS and in the
>> functionality I checked Available and Queryable. But none of clients "sees"
>> this layer, and also with GETCAPABILITIES I don't see this layer. Only
>> layers I see are those from Sheboygan example. So, what else need I do to
>> publish layer with WFS? Just to mention, layer is seen through WMS service.
>> View this message in context: http://n2.nabble.com/WFS-publishing-question-tp2740434p2740434.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
