[mapguide-users] Set Filter In operator
padmini godavarthi
godavarthi.padmini at gmail.com
Thu Apr 30 01:44:55 EDT 2009
iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
Now my problem is "In" operator is not working in Setfilter option
My code is as follows..................................
Dim queryoptions As MgFeatureQueryOptions = New MgFeatureQueryOptions()
queryoptions.AddFeatureProperty("LINK_ID")
queryoptions.SetFilter("LINK_ID IN (170,143,150)")
Dim increment1 As Double = IIf((5 > 1), 1.0 / (5 - 1), 1.0)
Dim str As String = layer.GetFeatureClassName()
Dim dataReader1 As MgFeatureReader =
featureService.SelectFeatures(resId, layer.GetFeatureClassName(),
queryoptions)
While dataReader1.ReadNext()
value = GetFeaturePropertyValue(dataReader1, "LINK_ID")
filterText = """ + "LINK_ID" + "" = "
filterText = filterText + value
areaRuleXML = String.Format(areaRuleTemplate, "LINK_ID" + ":" +
value, filterText, InterpolateColor(portion, "00FF00", "00FF00", 0),
InterpolateColor(portion, "00FF00", "00FF00", 0))
areaDoc = New XmlDocument()
areaDoc.LoadXml(areaRuleXML)
areaNode = doc.ImportNode(areaDoc.DocumentElement, True)
areaTypeStyle.AppendChild(areaNode)
portion = portion + increment1
End While
dataReader1.Close()
It gives me the following error
queryoptions)
as
An exception occurred in FDO component.
ORA-00907: missing right parenthesis
In this case Link ID is integer values not a string
value......................................:-(
can u plz tell me the solution
i have also tried as
queryoptions.SetFilter("LINK_ID IN ({170},{143},{150})") but it gave me
the error as "not a valid filter"
Can anyone plz tell me the solution???????????????????/
plzzzzzzzzzzzzzzzz
Regards,
Padmini.
View this message in context: http://n2.nabble.com/Set-Filter-In-operator-tp2745314p2745314.html
