[mapguide-users] can anyone solved this buffer problem
padmini godavarthi
godavarthi.padmini at gmail.com
Thu Apr 30 04:13:40 EDT 2009
Hi Kenneth,
i have created a buffer with 0.2 miles but i think the buffer is not
creating accurately
http://n2.nabble.com/file/n2745746/buffer.jpeg
1) can u provide any solution?????????????
2)And can u plz tell me the code for retrieving parcel_id with in the buffer
area(im a little bit confused)
plzzzzzzzz
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> It looks correct to me. Try using a smaller buffer to better determine
> accuracy.
> For the second question, you have already asked that in another thread.
> The AJAX viewer shows selection data, so try looking at the
> selection.aspx files,
> and see how it works.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>> Thanku very much for ur help.............
>> i did the coordinate system override as per ur instructions.
>> It works fine
>> but i felt that the buffer feature is not coming accurately??
>> what was the problem????????????????????????????
>> i mean by observing closely its not an accurate circle(buffer layer).
>> http://n2.nabble.com/file/n2683455/pic.jpeg
>> 2)secondly i want to retrieve the parcel_ids that are included or
>> intersected in the buffer layer.How is it possible ? can u send me the
>> sample code?????????
>> Thanks in advance.
>> Regards,
>> Padmini.
>>> Thats because the Sheboygan data uses a true georeferenced coordinate
>>> system,
>>> and your data is using a non-georeferenced system, like XY-M.
>>> Arbitrary should be understood as "non-georeferenced".
>>> If your data is not in the same projection as the map, you cannot use
>>> the buffer feature.
>>> This then returns to my initial statement: "Coordinate System Override",
>>> which can
>>> set the data coordinate system to match the maps.
>>> Can you please report what happened with with the suggestions I made,
>>> regarding the coordinate system overrides?
>>>> Hi,
>>>> In my data
>>>> bool arbitraryMapSrs = (srsMap.GetType() ==
>>>> MgCoordinateSystemType.Arbitrary);
>>>> arbitraryMapSrs comes as true but in sheboygan data it comes as false
>>>> if (arbitraryMapSrs)
>>>> mapSrsUnits = srsMap.GetUnits();
>>>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it comes
>>>> as
>>>> null
>>>> so that
>>>> if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>>>> (dsSrsUnits
>>>> != mapSrsUnits)))
>>>> excludedLayers++;
>>>> continue;
>>>> In my data excludedLayers comes as 1 and where as in sheboyan data
>>>> this
>>>> condition fails....................
>>>> Can u plz provide me the solution?????????????
>>>> Regards,
>>>> Padmini.
>>>>> Why do you mention packages?
>>>>> excludedLayers is incremented because the data coordinate system is
>>>>> not
>>>>> the same as the map coodinate system.
>>>>> Please comment on what happend when you attempted my previous
>>>>> suggestions.
>>>>>> Hi Kenneth,
>>>>>> Thanks for ur suggestions.
>>>>>> I have created a package using OGR provider but in the buffering i
>>>>>> found
>>>>>> some problem that
>>>>>> // exclude layer if:
>>>>>> // the map is non-arbitrary and the layer is arbitrary
>>>>>> or
>>>>>> vice-versa
>>>>>> // or
>>>>>> // layer and map are both arbitrary but have different
>>>>>> units
>>>>>> (arbitraryDsSrs
>>>>>> (dsSrsUnits != mapSrsUnits)))
>>>>>> excludedLayers++;
>>>>>> continue;
>>>>>> it gives difference to my data and sheboygan sample data
>>>>>> so that in my code excludedLayers is incremented to 1 so i didnt get
>>>>>> the
>>>>>> buffer features
>>>>>> can u plz tell me the solution?????????????????
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> I'm not sure that provider is case insensitive.
>>>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>>>> Also, try creating a folder, and place the files in the folder.
>>>>>>> Then try to use the "External files" and point to the folder.
>>>>>>> Also try pointing directly to the file.
>>>>>>> When the "Test connection" is successfull, try clicking the
>>>>>>> rightmost button in the "coordinate system override" field, and
>>>>>>> it will show you what the provider returns as the coordinate system.
>>>>>>> Alternatively, try using the OGR provider instead of the SHP
>>>>>>> provider.
>>>>>>>> Hi Keneneth,
>>>>>>>> First of all thanks for ur patience
>>>>>>>> i have uploaded all the files but i didnt get the coordinate system
>>>>>>>> http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>>>> again i did anything wrong??????????
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>>>> You must upload all the "Properties.*" files to the datasource,
>>>>>>>>> even if the upload file dialog is misleading (you must select "All
>>>>>>>>> files" to see them).
>>>>>>>>> A ticket for this problem is here.
>>>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>>>> Hi,
>>>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>>>> my code as same as previous
>>>>>>>>>> MgResourceIdentifier featSourceId = new
>>>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>>>> MgSpatialContextReader ctxs =
>>>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>>>> String srsDefDs = "";
>>>>>>>>>> if (ctxs != null && ctxs.ReadNext())
>>>>>>>>>> srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>>>> in srsDefDs i got null
>>>>>>>>>> does i did any thing wrong
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system, so
>>>>>>>>>>> you
>>>>>>>>>>> have
>>>>>>>>>>> to specify it manually.
>>>>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> thanks but is it necessary overriding a coordinate
>>>>>>>>>>>> system????????
>>>>>>>>>>>> How it willbe done???????
>>>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>>>> i have seen ur link but no data available in that for overrides
>>>>>>>>>>>> coordinate
>>>>>>>>>>>> system
>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>> No, I meant "Coordinate System Override", which is located on
>>>>>>>>>>>>> the
>>>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>>>> See screenshots here:
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>>>> iam using maestro and i have selected the coordinate system
>>>>>>>>>>>>>> as
>>>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data but
>>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>> data
>>>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>>>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees, -180
>>>>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>>>> srsDefDs comes as null
>>>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p2745746.html
