[mapguide-users] can anyone solved this buffer problem
Ivan Milicevic Ivan.Milicevic at supranet.hr
Thu Apr 30 04:22:35 EDT 2009
Padmini, why do you think that there is something wrong with buffer???
It's look good to me. The strange shape is because you have created
buffer ffrom selected polygon.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
godavarthi
Sent: Thursday, April 30, 2009 10:14 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] can anyone solved this buffer problem
Hi Kenneth,
  i have created a buffer with 0.2 miles but i think the buffer is not
creating accurately
     http://n2.nabble.com/file/n2745746/buffer.jpeg
1) can u provide any solution?????????????
2)And can u plz tell me the code for retrieving parcel_id with in the
buffer
area(im a little bit confused)
plzzzzzzzz
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> It looks correct to me. Try using a smaller buffer to better determine
> accuracy.
> For the second question, you have already asked that in another
thread.
> The AJAX viewer shows selection data, so try looking at the
> selection.aspx files,
> and see how it works.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi  Kenneth,
>> Thanku very much for ur help.............
>> i did the coordinate system override as per ur instructions.
>> It works fine
>> but i felt that the buffer feature is not coming accurately??
>> what was the problem????????????????????????????
>> i mean by observing closely  its not an accurate circle(buffer
layer).
>> http://n2.nabble.com/file/n2683455/pic.jpeg
>> 2)secondly i want to retrieve the parcel_ids that are included or
>> intersected in the buffer layer.How  is it possible ? can u send me
the
>> sample code?????????
>> Thanks in advance.
>> Regards,
>> Padmini.
>>> Thats because the Sheboygan data uses a true georeferenced
coordinate
>>> system,
>>> and your data is using a non-georeferenced system, like XY-M.
>>> Arbitrary should be understood as "non-georeferenced".
>>> If your data is not in the same projection as the map, you cannot
use
>>> the buffer feature.
>>> This then returns to my initial statement: "Coordinate System
Override",
>>> which can
>>> set the data coordinate system to match the maps.
>>> Can you please report what happened with with the suggestions I
made,
>>> regarding the coordinate system overrides?
>>>> Hi,
>>>> In my data
>>>>     bool arbitraryMapSrs = (srsMap.GetType() ==
>>>> MgCoordinateSystemType.Arbitrary);
>>>> arbitraryMapSrs comes as true but in sheboygan data it comes as
false
>>>>         if (arbitraryMapSrs)
>>>>             mapSrsUnits = srsMap.GetUnits();
>>>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it
comes
>>>> as
>>>> null
>>>> so that
>>>>  if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>>>> (dsSrsUnits
>>>> != mapSrsUnits)))
>>>>                 excludedLayers++;
>>>>                 continue;
>>>> In my data  excludedLayers comes as 1 and where as in sheboyan data
>>>> this
>>>> condition fails....................
>>>> Can u plz provide me the solution?????????????
>>>> Regards,
>>>> Padmini.
>>>>> Why do you mention packages?
>>>>> excludedLayers is incremented because the data coordinate system
is
>>>>> not
>>>>> the same as the map coodinate system.
>>>>> Please comment on what happend when you attempted my previous
>>>>> suggestions.
>>>>>> Hi Kenneth,
>>>>>> Thanks for ur suggestions.
>>>>>> I have created a package using OGR provider but in the buffering
i
>>>>>> found
>>>>>> some problem that
>>>>>>      // exclude layer if:
>>>>>>             //  the map is non-arbitrary and the layer is
arbitrary
>>>>>> or
>>>>>> vice-versa
>>>>>>             //     or
>>>>>>             //  layer and map are both arbitrary but have
different
>>>>>> units
>>>>>> (arbitraryDsSrs
>>>>>> (dsSrsUnits != mapSrsUnits)))
>>>>>>                 excludedLayers++;
>>>>>>                 continue;
>>>>>> it gives difference to my data and sheboygan sample data
>>>>>> so that in my code  excludedLayers is incremented to 1 so i didnt
get
>>>>>> the
>>>>>> buffer features
>>>>>> can u plz tell me the solution?????????????????
>>>>>> Regards,
>>>>>> Padmini.
>>>>>>> I'm not sure that provider is case insensitive.
>>>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>>>> Also, try creating a folder, and place the files in the folder.
>>>>>>> Then try to use the "External files" and point to the folder.
>>>>>>> Also try pointing directly to the file.
>>>>>>> When the "Test connection" is successfull, try clicking the
>>>>>>> rightmost button in the "coordinate system override" field, and
>>>>>>> it will show you what the provider returns as the coordinate
system.
>>>>>>> Alternatively, try using the OGR provider instead of the SHP
>>>>>>> provider.
>>>>>>>> Hi Keneneth,
>>>>>>>> First of all thanks for ur patience
>>>>>>>> i have uploaded all the files but i didnt get the coordinate
system
>>>>>>>>     http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>>>> again i did anything wrong??????????
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>>>> You must upload all the "Properties.*" files to the
datasource,
>>>>>>>>> even if the upload file dialog is misleading (you must select
"All
>>>>>>>>> files" to see them).
>>>>>>>>> A ticket for this problem is here.
>>>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>>>> Hi,
>>>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>>>> my code as same as previous
>>>>>>>>>>  MgResourceIdentifier featSourceId = new
>>>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>>>>             MgSpatialContextReader ctxs =
>>>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>>>>             String srsDefDs = "";
>>>>>>>>>>             if (ctxs != null && ctxs.ReadNext())
>>>>>>>>>>       srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>>>> in  srsDefDs i got null
>>>>>>>>>> does i did any thing wrong
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system,
so
>>>>>>>>>>> you
>>>>>>>>>>> have
>>>>>>>>>>> to specify it manually.
>>>>>>>>>>> There is a short explanation on how to use overrides here:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> thanks but is it necessary overriding a coordinate
>>>>>>>>>>>> system????????
>>>>>>>>>>>> How it willbe done???????
>>>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>>>> i have seen ur link but no data available in that for
overrides
>>>>>>>>>>>> coordinate
>>>>>>>>>>>> system
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSour
ce
>>>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>> No, I meant "Coordinate System Override", which is located
on
>>>>>>>>>>>>> the
>>>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>>>> See screenshots here:
ce
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>>>> iam using maestro and i have selected  the coordinate
system
>>>>>>>>>>>>>> as
>>>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS
5.1)
>>>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data
but
>>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>> data
>>>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>>>> srsDefDs comes as  GEOGCS["WGS84 Lat/Long's, Degrees,
-180
+180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",637813
7,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199
43295]]
>>>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>>>>   srsDefDs comes as null
>>>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,
0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901
"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORIT
Y["EPSG","4326"]]
>>>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context:
http://n2.nabble.com/can-anyone-solved-this-buffer-problem-tp2675600p274
5746.html
