[mapguide-users] freeBSD install
Jackie Ng
jumpinjackie at gmail.com
Thu Apr 30 14:12:17 EDT 2009
Fusion runs on top of MapGuide, which uses FDO. So yes you need to compile
both.
You're probably the first one to try compiling on BSD. So you're probably on
your own here. Do let us know if you have success :-)
- Jackie
Marco Battistella wrote:
> Hi,
> I am attempting to create a install of fusion/mapguide/fdo in a
> FreeBSD environment.
> I am encountering a number of issues and i hope someone here can help.
> First, i'm not quite clear of the different requirements etc...
> I was provided the fusion files created some time ago by a third party.
> Reading the installation requirements for these files i understand
> that the following should be available:
> - webserver (apache 2.2.x) - not a problem
> - php - not a problem
> - mapguide (which i guess requires java sdk in order to be built)
> - fdo (required by mapguide)
> I have downloaded the linux install for fdo but i run into a whole
> series of errors, i'm not going to get into it, just yet.
> My first question is: am i understanding it correctly? Do i need to
> install/compile mapguide and fdo in order to have a functional fusion
> install?
> My second question: has anyone built these under FreeBSD before? And
> if so, what's the trick? :-)
> Thank you for any reply.
> Marco
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/freeBSD-install-tp2748563p2748749.html
