[mapguide-users] initial displacement of map content
Chris Claydon
chris.claydon at autodesk.com
Sun Aug 2 02:48:51 EDT 2009
This sounds like a defect that I thought had been fixed a long time
ago. Which version of the MapGuide web tier are you using?
Also, do you have the property panel disabled? I think that was the
case when I last saw this issue.
Sent from my iPhone
On 2009-08-01, at 4:01 PM, "stoff" <mail at effing.org> wrote:
> Hi,
> I have a displacement of the map within the Ajax-Viewer (a white gap
> at the
> top of
> the map). It happens on initial map visualization and disappears
> when the
> splitter
> between layerctrl and mapframe is moved ...
> http://n2.nabble.com/file/n3370781/versatz.jpg
> Any hints are welcome ...
> Best regards,
> Stoff
> View this message in context: http://n2.nabble.com/initial-displacement-of-map-content-tp3370781p3370781.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
